the box in my car is an r33 turbo box but from one to two its got a nice notch to it and if i dont be really careful itll crunch.
the rest of the gears are perfect in the way they feel.
is it possible to just rebuild/replace the old syncro's in that gear?
im not in a place thats easy to ask.
they keep telling me they just send the box away and get another back. but thats 1300ish and id prefer not to spend that in my current situation....
is it possible to just do the gear that needs doing?
thanks
https://www.sau.com.au/forums/topic/323834-box-rebuild/
AFAIK you can just replace the 1 synchro that is crunching....but if one is gone the rest almost certainly are going or gone too. And there are bearings and seals that should be replaced too.
BTW 1300 sounds cheap to replace all the synchros and bearings. Or is that the cost to get another second handbox? If so I'd probably give it a miss, almost every box will have these issues to some extent by now.
You can just do what most people do - run the Redline Lightweight shockproof gear oil and slow down your gear changes a little....it won't fix anything but it might hide the problem for a few years.
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5278050
1300 is a reconditioned box
a second hand bax goes from about 300 to 600 here.
if shockproof is that good i might give it a go. althought i have heard some stories that some times it makes it worse.
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5278108
i have the same gearbox and i personally rebuilt it a few months ago. trust me - if your going to replace one synchro you should replace them all, as well as all bearings in it. never trust a 2nd hand gearbox, you just have no way of knowing what condition its in. sure it could run fine now, but how long will that last? these gearboxes are all getting old now and i would put money on the fact that every one of them has seen a good bit of abuse over the years so i definately wouldnt waste my time with a 2nd hand box, you really are opening a can of worms if you do.
to get at the 1st/2nd gear synchros the whole box basically needs to be stripped which is a big job, and since you dont tend to strip your gearbox very often it would be a pretty dumb idea not to do the rest of them while your in there, as they are more than likely not far away from doing the same thing. be warned though, syncro's are expensive. they are likely to cost just as much or perhaps more than the labour charge to do it. over here in nz they were $1160 with trade discount. dont be suprised if you find them around $1000AUD.
see the reference picture attached this is of my actual gearbox during the rebuild. it points out where the synchros are in case your unfamiliar with what your up against. they are the bronze coloured rings highlighted by the arrows. if you dont have any experience with gearboxes do NOT attempt it yourself. even for me this thing was a bit of a nightmare
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5282300
What the hell? where is "here"???
My 25t box cost me $1500 2nd hand!!
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5286157
thanks for the info.
makes a bit more sense now.
im in japan.
there between 300 and 600 depending where you buy it and how much risk you take on it being good or bad.
to have a box changed at a shop here is 200-300 plus oil. if i was at home in aus id do it myself where here i cant which is a bugger.
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5286313
im in japan.
Wow.
When I went to upgrade to a 25t box, it was $1500 for an unknown 2nd hand with no guarantees and that seems to be the going price everywhere over here.. occaisionally you'll see one for $1200 from a private seller.
It's quite annoying and disgusting but hey, what can you do? For $600 for the least risk I'd break 3 and replace until I felt I needed to rebuild one.
GTR boxes go for 600ish but a fair effort to turn it into rwd.
Good luck :/
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5288064
i bought an unknown condition 25t box over here in WA for $300. pulled it apart it had signs of water being inside but other than that im sticking a kit an sychros through it which cost twice the price of the box
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5290016
Are you doing it yourself?
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5292067
Can you lap in old syncro's in skyline box's. When I was in the Automotive industry. Lasted 4 weeks. One of the head mechanics said you can lap in some of the holden syncro's to make them work again. I guess they become glazed or the scores on them wear off?
Wondering if it works or if people have heard of it or tried?
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5298629
bubba, yeah i can do more for ya. am located in bunbury tho.
you can use fine valve lapping paste to lap the synchro back into the cone but if its to worn its just a waste of time and you'd be better off with new synchros
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5300211
Cool, bunnos not really that far away ;)
We'll see how long the current box lasts when the new engine/turbo setup is in.. the box has crunched 2nd a bit ever since I got it :( I got around that by just starting in 2nd instead of trying to hit 2nd :)
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5310761
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
