hey guys,
trying to sort out this issue im having with the idle in my car. just some specs on the motor
r34 gtt
exhaust port+match rb26 head
fully forged rb30 bottom end
gt35 .82
vband straight pipe 3.5" exhaust
1000cc inj
OEM rb26 plenum + tbs
OEM rb26 cams
PFC D jetro ecu
while in motion at any speed if i clutch in the revs go up to ~2000rpm and sit there until the car comes to a stop where it will drop down to around ~1700rpm. sometimes it will bounce around from ~1000rpm to ~2000rpm, somtimes will just sit at 2300rpm.
occasionally when i start the car on a cold day/night it will idle nice at 1000-1200rpm but as soon as the car gets moving and i eventually have to stop and clutch in, the above scenario starts.
im spoken to my tuner and he seems to have tried a few things like playing around with the idle control valve (not sure on specifics) but has had no success. his mentioned something about it being 3L and the amount of air the motor flows is so high, its causing problems.
i see 800hp cars idle nice and fine so why cant i? i dont know much about the tuning side of it and was wondering what can be done about it? i should mention that i had no issues what so ever when i ran a single plazmaman plenum + 80mm tb when i had a rb25 in the car.
any help much appreciated guys! i look like a completely idiot at the lights with such a high idle :)
https://www.sau.com.au/forums/topic/323850-high-idle/
do you have any vaccume leaks? they can cause a high idle with a MAP ecu. if not have you tried taking the idle control valve off and cleaning the carbon/oil out of it?
does it only idle funny when cold? or it still has a high idle when at operating temp?
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5277974
it idles high all the time.
only sometimes when the motor is cold it idles lower but only sometimes, but as soon as i start driving it starts idling high again.
i highly doubt i have any vacuum leaks because i have no boost issues. ill will confirm with my tuner if he actually cleaned the control idle valve.
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5277985
lol @ RB30 thing....for starters I would not trust your tuner if his last resort blame was that. As said, engines need excessive air to have high idle.
Did you inspect the new rb26 throttle setup before putting it on the head?
Make sure they were fully opening and closing with no issues and not open too much when closed?
As said you may just need to play with the adjustment. However, usually it is just the idle control valve....
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5278061
Did u clean the throttle bodies with carby cleaner? I did this to my 1st rb26 and had similar symptoms. I had to replace the throttle bodies.
Check there is no air leaks at the throttle bodies either. Can also try blocking the idle control valves air pipe. If it idles fine then u need a new idle control valve.
Last but not least disconnect all of the throttle linkages from the main linkage and see if the idle is fixed they might be over adjusted
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5278076
+1 ^^^^
If u cleaned the throttle bodies you can get this
Don't know if the idle control valve these guys are referring to is the aac valve but there is also a air regulator under the plenum close up against the block.....this is used for cold starts.
If it is shagged or unplugged you will get similar symptoms.....to reach it is a real bitch! .....good luck
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5278112
hi i had that exact same problem on my other car that i sold an i tryed heaps of different things an guy who bought it called me a few days ago to tell me all he did was replace the AFM an now the idle has returned to 100% normal, so diffinatly check that..
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5278698
lol what?
Silly tuner you are using mate - go somewhere else if those such comments are being made.
And given you've had power/setup issues for a long time given such comments, perhaps you really do need another workshop/tuner?
As the others have said - it'll be VAC leaks/TB/idle controller. It can't really be anything else :D
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5279149
Im not sure if the ECU you are using has the air regulator operating but i suspect so as it runs in conjunction with the AAC valve. As the thread above states it hard to get too but you will have to visually expect that the shutter is not jamed in a position.
I.E At -20 degrees the valve is fully open
at 20 degrees it is half open and
at 60 degrees it is compleatly closed
I am ony guessing and not sure as MAP sensors are tricky but its worth a shot at checking if the valve is faulty. Another trick is the attach a 12volt DC battery to it
Positive to terminal number one and negative to number 2
Say the surrounding area temp was 20 degrees it would open half way (allow a few mins for it to slowly open) and measure the resistance and is should be near 80
The AAC valve should be checked as well, Somtimes the spring is stuffed or the plunger on the switch so also have a look there. Also check the resistance on the AAC valve which shoul read somewhere near 7.
Keep in mind a vac leak will give faulty readings through these valves so thats another place too look while pulling these bits out. (all hoses around the air control system of the car)
Edited by central coast person
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5279421
hi
please check the basics
check pipework, solenoids, idle control (basically what the others have said)
post a photo of ETC, SENSOR SW CHECK
post a photo of ETC, FUNCTION SELECT
post a photo of SETTING, REV LIMIT
if you cant work out how to get these, learn here
http://www.paulr33.com/powerfc-emulator/menu.html
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5279490
+1 on the cold start valve, I had the exact problem, sitting at about the exact same revs as you.it pretty much sits in between the plenum/intake manifold and low on the head, on the firewall side of the throttle body(if you are running standard plenum). I think its bolted to the intake manifold by 2 bolts. It t has 2 hoses running too it and a plug connects to the top of it.
The way it is designed is a tiny spring inside it is supposed to hold it shut(or open, I forgot). When voltage is applied the solenoid should open or close it. All you will need to do is open it up, be very careful to not lose any parts, reconnect the spring, then put it back together making sure it has sealed perfectly.
Hopefully that is the issue but based on what the tuner said it could even be a tune issue(however I doubt it would rev that high with just the AAC valve letting air in).
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-5279576
  • 1 year later...
Update on the situation.
Acid cleaned all throttle bodies, replaced the shaft seals with aftermarket ones from the states.
More info - http://www.xs-engine...idproduct=12106
Replaced the AAC valve (23781-05U11)
picture = http://simex.sakura....es-DSCN7515.jpg
3 coats of tomei throttle coat and no difference what so ever.
hi
http://www.paulr33.c...lator/menu.html
hey paul,
Could you elaborate on exactly what the cold start valve is? Are you referring to the "Idle Control Regulator" part no = 22660-01U10?
this thing here?
Edited by Jap_Muscle
https://www.sau.com.au/forums/topic/323850-high-idle/#findComment-6035847
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
