Hi.
I'm almost done with a rebuild, but I can't fit on the oil pan, because the oil filter net is blocking. :)
I have almost given up, I consider to cut the "oil pipe" in half, and just fit a hose instead (see pic below).
Does anyone have a experience with this that can give me a better solution ?
Thanks.
Edited by Iceman22
https://www.sau.com.au/forums/topic/323854-problem-to-install-the-oil-pan/
If you took it off while in the car then surely you can put it back on in the reverse order. The filter head is pretty important, I wouldnt be cutting it off and replacing it with a perishable piece of hose and no coarse filtration before the pump.
Yeah I totaly agree on that. I used a lot of strenght to get it out, have tried to put it back long time now but I can't do it.
It's surely something I do wrong but I don't know what.
My guess is when using "a lot of strenght" to get it out you have bent the neck....?
