Well I figure its about time I did a little update on the R30 I brought 6months or so back.
Im not posting any photos yet as I want to do a before and after piece.
however I have since getting it done the following..
-stripped and replaced the interior and fitted recaro seats
-added gauges oil,water,volts
-fitted blitz SBC ID 2 boost controller
-facelift front, all but the bonnet
-fitted 17” original goods wheels
-exhaust changed 3’ right through
-new intake and filter
-stripped all sound deadening all 32.3kgs worth!
-fitted genuine mirrors
-fitted R32 brakes (still figuring out the best option for tie rods)
-s13 coilovers front
-r33 coilovers rear
-10mm rear wheel spacers (when you see pics you will understand)
-standard side skirts fitted
-two tone paint
Also on the weekend I did a dyno day just thought id see how she was going..
Now the engine is 2.2ltr has forged pistons a full metal head gasket plus a Vg30 turbo with large intercooler a bosch 650hp fuel pump and a mines computer it has standard injectors..
It made 171.5rwkw@ 14.3 psi but was starting to lean so it could not run higher than that the tuner said with bigger injectors it would easily go way past there saying it felt very strong..
How ever im happy with this power for now it wont put the power to the road until 3rd anyway and am running 235s!
Marc
https://www.sau.com.au/forums/topic/323858-update/
  • Replies 66
How big you want the injectors Marc?
I have a NEW set of 570cc Siemens Deka injectors I probably wont be using, but need a 14mm O'ring fuel rail to fit them.
Also 6 x 460cc S2 RX7 and connector plugs to suit that you can have real cheap.
Your stock injectors are 375cc.
"a full metal head gasket"
Your gunna be sooooorrry!
Where is your safety valve, for when you detonate for lean out, or a bad dose of fuel, or whatever?
D.
https://www.sau.com.au/forums/topic/323858-update/#findComment-5278213
D.
what who when where? lol gasket was prefitted i didnt put it on the car it seems fine i think ill be fine..
im not sure about injectors at this point ill probably just get 510cc mitsubishi ones but not sure just yet it all depends on if i want to go further with it which at this point i dont.
iv got the car weighing 1073kgs with me in it so that plus 171kw its very quick imo..
as for pics they will come but i want to finish it first so i can do before and after
marc
https://www.sau.com.au/forums/topic/323858-update/#findComment-5278531
  • 4 weeks later...
AAAAAH this car!! I know it well...Randy from Nissco (in Halbert St Bayswater) built it with his son Vincent (orig owner a few years back)
They commented that it was one of the only FJ's they had to chain down on the dyno as it kept trying to jump off the rollers! Came on boost VERY hard.
WOW this looks so much better too... what did you use for the lower half paint? details???
I really like the rims, they look like what was going around in 1984. What $$$ you chasing?
Get it finished for the Skyline Nationals too, only a few months to go. September.
https://www.sau.com.au/forums/topic/323858-update/#findComment-5326988
thanks guys.
i will have it finished if i can get the TI bumper and a bonnet im chasing come on people help me out here lol
also the wheels are 17" Original goods "Bansai" good tyres 4x114.3 +11 offset from memory
i want 1000 with the tires
the wheels are mint
https://www.sau.com.au/forums/topic/323858-update/#findComment-5327182
OK i forgot about the Ti bumper, its out the back still.
I'll pass on the wheels, I dont want anything bigger than 16"
its all good have you got a Ti bumper rear have you? lets do a deal!! cheap please as it will need to make its way to me in melb!.....
its was not an r31 front it was of a prarie or such i think it went in the bin as soon as the car got to me!
Edited by FJ20DR30
https://www.sau.com.au/forums/topic/323858-update/#findComment-5327978
  • 4 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
