Well I figure its about time I did a little update on the R30 I brought 6months or so back.
Im not posting any photos yet as I want to do a before and after piece.
however I have since getting it done the following..
-stripped and replaced the interior and fitted recaro seats
-added gauges oil,water,volts
-fitted blitz SBC ID 2 boost controller
-facelift front, all but the bonnet
-fitted 17” original goods wheels
-exhaust changed 3’ right through
-new intake and filter
-stripped all sound deadening all 32.3kgs worth!
-fitted genuine mirrors
-fitted R32 brakes (still figuring out the best option for tie rods)
-s13 coilovers front
-r33 coilovers rear
-10mm rear wheel spacers (when you see pics you will understand)
-standard side skirts fitted
-two tone paint
Also on the weekend I did a dyno day just thought id see how she was going..
Now the engine is 2.2ltr has forged pistons a full metal head gasket plus a Vg30 turbo with large intercooler a bosch 650hp fuel pump and a mines computer it has standard injectors..
It made 171.5rwkw@ 14.3 psi but was starting to lean so it could not run higher than that the tuner said with bigger injectors it would easily go way past there saying it felt very strong..
How ever im happy with this power for now it wont put the power to the road until 3rd anyway and am running 235s!
Marc
https://www.sau.com.au/forums/topic/323858-update/
  • Replies 66
How big you want the injectors Marc?
I have a NEW set of 570cc Siemens Deka injectors I probably wont be using, but need a 14mm O'ring fuel rail to fit them.
Also 6 x 460cc S2 RX7 and connector plugs to suit that you can have real cheap.
Your stock injectors are 375cc.
"a full metal head gasket"
Your gunna be sooooorrry!
Where is your safety valve, for when you detonate for lean out, or a bad dose of fuel, or whatever?
D.
https://www.sau.com.au/forums/topic/323858-update/#findComment-5278213
D.
what who when where? lol gasket was prefitted i didnt put it on the car it seems fine i think ill be fine..
im not sure about injectors at this point ill probably just get 510cc mitsubishi ones but not sure just yet it all depends on if i want to go further with it which at this point i dont.
iv got the car weighing 1073kgs with me in it so that plus 171kw its very quick imo..
as for pics they will come but i want to finish it first so i can do before and after
marc
https://www.sau.com.au/forums/topic/323858-update/#findComment-5278531
  • 4 weeks later...
AAAAAH this car!! I know it well...Randy from Nissco (in Halbert St Bayswater) built it with his son Vincent (orig owner a few years back)
They commented that it was one of the only FJ's they had to chain down on the dyno as it kept trying to jump off the rollers! Came on boost VERY hard.
WOW this looks so much better too... what did you use for the lower half paint? details???
I really like the rims, they look like what was going around in 1984. What $$$ you chasing?
Get it finished for the Skyline Nationals too, only a few months to go. September.
https://www.sau.com.au/forums/topic/323858-update/#findComment-5326988
thanks guys.
i will have it finished if i can get the TI bumper and a bonnet im chasing come on people help me out here lol
also the wheels are 17" Original goods "Bansai" good tyres 4x114.3 +11 offset from memory
i want 1000 with the tires
the wheels are mint
https://www.sau.com.au/forums/topic/323858-update/#findComment-5327182
OK i forgot about the Ti bumper, its out the back still.
I'll pass on the wheels, I dont want anything bigger than 16"
its all good have you got a Ti bumper rear have you? lets do a deal!! cheap please as it will need to make its way to me in melb!.....
its was not an r31 front it was of a prarie or such i think it went in the bin as soon as the car got to me!
Edited by FJ20DR30
https://www.sau.com.au/forums/topic/323858-update/#findComment-5327978
  • 4 weeks later...
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
