Just received this email from a friend in the Porsche Car Club... Anyone think they are a chance of going?
Motorists wanting to drive fast without getting fined or locked up for speeding now have a safe location to test their cars performance.
Management at Sydney's Eastern Creek Raceway are making the race circuit available to licensed drivers to lap the track in road-registered cars as fast as they wish.
An Eastern Creek twilight drive night is being conducted from 5.30pm till 8.00pm on Wednesday evening January 28, 2004.
Responsible enthusiasts now have the opportunity to enjoy the power of their cars in a safe controlled environment. Drivers need to hold a full licence and be over 18 years of age, cars must be registered and road worthy.
A limited number of cars are on track in each session. Overtaking is only permitted on the main straight. Officials outline the strictly enforced track rules at a drivers meeting following the 4.00pm sign on.
WHAT: Twilight drive night. No speed limit
WHEN: Wednesday evening January 28, 2004
4.00pm Sign on
5.00pm Drivers meeting.
5.30pm 1st on track session
8.00pm Concludes
WHERE: Eastern Creek Raceway. Enter via gate 7
COST: $75.00 inc GST per driver.
Regulations: Drivers must be over 18 years of age and require:
Full drivers licence (no P plates).
Cars must be registered and road worthy.
Approved crash helmet must be worn along with a non synthetic long sleeve shirt, long pants and enclosed shoes.
An indemnity document is to be signed.
FUTHER INFO EASTERN CREEK RACEWAY
Ph: (02) 96721000
Email: [email protected]
https://www.sau.com.au/forums/topic/32388-ec-twilight-drive-night-28th-jan/
sweet...more track days!
It wont be dark by 8pm although sun will be low.
Racing at night is one of the most amazing experiences - try hitting apexes exactly when you can only see the reach of your headlights :cheers:
Twilight drive was farkin awesome !! :( , and the drifters put on a good show... just didnt have much time to see the drift and have a drive. It was a great chance to learn the limits of the skyline and maybe I learnt how to steer it a bit better. There was some mad cars that showed but only one other skyline, a gtr from targa tas.... now that was quick, hope to see some other skylines next time. I'll be there for sure !!
cheers
Lenno
I followed that Just Jap R33 GTR all the way along great western h/way till i turned off. It had number 53 i think of the side of it and a full roll cage, also a few Motul stickers.
That thing was a rocket, hardly even reving it, and it was just pulling away at each set of lights.
Looked tuff :D
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
