item Summary:1990 Nissan Sileighty.
as i need a price ill just say 10k as im ony interested in swaps for a R32, R33 or Cefiro if you have one or know of one contact me via PM
also contact me via pm for full details of car.
Pics: here are a few pics from what it was when i got it & as it is now.
https://www.sau.com.au/forums/topic/323889-sileighty/
Can't edit my posts for some reason so ill have to put the details here :laugh:
its a 1990 180sx/Sileighty
S13 Front conversion
CA18DET with under 100,00k's i think its 97,xxx might even be less
5 Speed
Bilstein Coilovers
Nismo style side skirts
Front & Rear Strut Braces
Nismo 3point race harnesses
5" tacho with shift light in cluster
Digital Cluster
pioneer cd/mp3 player
stripped rear interior ( still have everything )
aftermarket type X style tinted taillights with Type X RPS13 Carbon fiber center garnish
full 3" exhaust into 3.5" cannon
has a set of 16" jap rims but can come with a set of almost new 18" Lenso rims with brand new tyres
thats all i can think of atm ill post up more as i remember
& here are a few more pics
https://www.sau.com.au/forums/topic/323889-sileighty/#findComment-5283594
    • Thanks for the explanation, I'll sleep a little smarter tonight! Cheers.
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
