item Summary:1990 Nissan Sileighty.
as i need a price ill just say 10k as im ony interested in swaps for a R32, R33 or Cefiro if you have one or know of one contact me via PM
also contact me via pm for full details of car.
Pics: here are a few pics from what it was when i got it & as it is now.
https://www.sau.com.au/forums/topic/323889-sileighty/
Can't edit my posts for some reason so ill have to put the details here :laugh:
its a 1990 180sx/Sileighty
S13 Front conversion
CA18DET with under 100,00k's i think its 97,xxx might even be less
5 Speed
Bilstein Coilovers
Nismo style side skirts
Front & Rear Strut Braces
Nismo 3point race harnesses
5" tacho with shift light in cluster
Digital Cluster
pioneer cd/mp3 player
stripped rear interior ( still have everything )
aftermarket type X style tinted taillights with Type X RPS13 Carbon fiber center garnish
full 3" exhaust into 3.5" cannon
has a set of 16" jap rims but can come with a set of almost new 18" Lenso rims with brand new tyres
thats all i can think of atm ill post up more as i remember
& here are a few more pics
https://www.sau.com.au/forums/topic/323889-sileighty/#findComment-5283594
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
