Hey
I have set of Origin DNA-01 in Gunmetal,fronts 17x9+30 rears 17x9.5+30. They come with all the center caps still in the boxes with the plastic protection film on them.
I bought them NEW and took them straight to get them repainted in the same colour to get rid of the machined lip so they are now one solid colour. I only used the rims and tyres once for a drift day.
The front tyres are Federal 595 SS 215/45-17 fitted NEW and used for this 1 drift day. Rear tyres are Neuton NT5000 235/45-17 fitted NEW and only driven home on from the track.
Located in Adelaide but will freight at your cost.
PM or reply here.
Asking price $1350
Cheers
Edited by slippylotion
  • 3 months later...
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
