Cue roadtrip, we meet bright and early at local BP for snacks and air.
I put 34psi in, for good firmness on open road driving (19s with a 35 profile)
Mate pulls up (r33) and puts 45psi in his (18s with 35 profile)
So after much bickering I ended up putting 38psi in my car and hoping to god I didnt have explosions on the highway, and all the while he's convincing me to put more in
I mean, christ, I'm usually a 32psi kind of guy, are my tyres going to explode? How much do you guys pump in?
32 would be fine. If I have 5 people plus their luggage i might put 36 in the back.
When i first went on the track I put 45 psi in my street tyres but they were still not up to it so i went to semi slicks and then slicks.
So no they won't explode if you put 45 psi in but there is absolutely no point in doing so. You will just wear out the middle of the tread.
I run about 38 normally...on most road tyres it wil improve handling at the cost of comfort. I don't agree that it is enough pressure to wear out the inside of a tyre, mine wears pretty evenly.
I have run tyres up to 45psi but that is specific tyres on the race track. Too high for general road use to me.
Also check the sidewalls, the tyres will hav a maximum allowable pressure which is generally 45....
mine tyres rated to 40 or 45 psi.
on the old car which were rated to 34 usually ran 36, ride felt sooo much better and direct steering.
also better to be on the rating or slightly over inflated than under inflated, less chance of tyre blow out.
can't remember what profile the girl's are, but they're 19's and we run 40 psi, checked weekly. totally even tyre wear so far.
Edited by pyro-ns
Any idea what psi I should run? 225/30/20... Sorry for hijack!
i'd put in around 36-40psi. it really depends on how much harshness you can tolerate and how the rubber reacts to certain tyre pressures. all you can really do is monitor the tread wear and make sure that it's even on all fours. all other things being neutral (camber, castor, toe), too much pressure will result in a bald spot right in the middle of the tyre and too little will result in baldness on the outside edges of the tyre.
if you find that extra pressure makes the ride too harsh (unlikely), then take a couple psi out and see how that goes. or if you've got coilovers, turn the dampner a few clicks towards soft :D
What was his argument for putting 45psi in? I don't get why he would want 45psi on the street....more to the point why he would want it on the open road :D. I never put more than 36-38 psi in mine on the street...shit if i want more grip in the arse on the street I drop em down.
if you run a lot of stretch you need high pressures but i never go over 40
mine are normally 36-38 for better fuel consumption (plenty of grip with the awd)
and as jetwreck said, if you want more grip on the street you would drop them down a bit, you dont really need stiff sidewalls on the street but you need more straight line grip
I would be a little careful going over 40 psi on the open road due to higher running temps. Considering Chales Law of Thermodynamics (pressure is proportional to temperature in a given volume) if your tyre temps are likely to go up then you could easily end up with a tyre pressure approaching 50psi. Apart from the obvious lowering of grip, due to less sidewall deflection and reduced contact patch, the effects of a blowout will be much more pronounced. All that risk for a possible saving of 0.1% fuel mileage doesnt really add up IMO.
Try alternating the pressures fron to rear too - a difference of only 2psi can be felt quite easlily. If you want a little more direct feeling in the steering wheel while maintaining a rear grip bias, try going 2 psi higher on the front.
is that isothermal, adiabatic or polytropic expansion? haha
just studying for my thermal eng. exam as we speak
i'll put my money on isothermal cause it is due to heat
isothermal expansion the temp stays the same (p1v1=p2v2)
i dont think it really matters
195/70's i'd go with something normal 32-34 maybe
its a pretty high profile tyre
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
