When a tyre says its rated too 45psi i would assume they take into account that the tyre will heat up increasing pressure along the way. And with items where safety is a big issue i would also guess the tyres to be over-engineered to an decent extent (unless you have ultimate cheap china tyres then well good luck :domokun:).
On another note anyone ever run factory recommended pressures? Haven't looked on the 34 but in the old s13 it said something stupid like 24psi i never ran less than 38psi on that
is that isothermal, adiabatic or polytropic expansion? haha
just studying for my thermal eng. exam as we speak
obviously it would be polytropic, as isothermal refers to a system change in which the temperature remains as a constant, and adiabatic refers to a change in temperature CAUSED by a change in pressure, not the other way around. It could be described as a diabatic process, but personally I would refer to that as an isocaloric process, due to the heat being caused by an external energy infraction (in this case, friction)
:domokun:
When I used to work at BP and did tyre replacements/balance in the workshop usually you'd see pressures of up to 80psi to get the tyre to pop back on to the rim lip. Let it back down to the rated pressure then put it back on the car.
So there is plenty of leeway in the amount of pressure the tyre can handle.
But i wouldn't go putting that much in when it's on the car :domokun:, factoring in the 300-450kg load the tyre has to deal with.
:domokun:
can you please come and replace my lecturer, we call him the story teller because all he does it read the book to the class
coupled to the fact that he is indian (not being racist) its hard to understand him and so basically we've had to teach ourselves :(
Egad this is technical
I am now intruiged with different pressures for front/rear.
So a harder front pressure gives a nicer handling, with a little lower at the back for grip?
Say 36/38?
Edited by Oddy man
I would be a little careful going over 40 psi on the open road due to higher running temps. Considering Chales Law of Thermodynamics (pressure is proportional to temperature in a given volume) if your tyre temps are likely to go up then you could easily end up with a tyre pressure approaching 50psi. Apart from the obvious lowering of grip, due to less sidewall deflection and reduced contact patch, the effects of a blowout will be much more pronounced. All that risk for a possible saving of 0.1% fuel mileage doesnt really add up IMO.
Try alternating the pressures fron to rear too - a difference of only 2psi can be felt quite easlily. If you want a little more direct feeling in the steering wheel while maintaining a rear grip bias, try going 2 psi higher on the front.
Hence my pressures:
38summer
40winter.
I always ensure to do a hot pres. check on long hot drives if i know temps are high to start off with. Anything under 38 psi feels crap in both cars.
My 1600 was 32-34psi, So the cars weight aswell as tyre size and type do play a part.
maybe the increased pressure from the op was to increase rolling diameter by a poofteenth through slightly balooning the tyre.
be uncomfortable as hell though.
i never get too fussed about tyre pressures
if i ever get to the stage where i require that extra bit of feedback through the wheel, or additional grip then i'm drivig way too fast for the streets.
everytime i put new brand tyres on a car that i have not had before i rule a line across the tyre in liquid paper and drive it for a week, if the outer edges rub off first, increase pressure, middle, decrease pressure.
37 is my magic mark in the stagea under standard commuting situations
increased pressures are also better for towing as it stops wall flex, but too much and the pressures will get too high
rule of thumb here is set your tyres b4 you leave, if your tyres rise 4 psi after about 1 hour of driving they are perfect, not 4psi, then put in more air, let air out iff 5 etc.
the greater the load on the tyre the more crucial the 4psi rise is as a squatting wheel will generate more heat
did this on the epic journey in the stag towing the 2 ton trailer (green garden shed with wheels) 3000kms across AUS
not one blow out despite the fact we drove in the middle of summer on b grade roads.
blow outs are not caused by over inflation of the tyre but exessive heat in the wall
- according to caravanists and truckies
Edited by 910trx
That's an awesome idea!
Yep, tyre pressures are meant to be checked when the tyres are cold - this is one rule many people forget! When you've driven them enough for some heat to get into them, then you have to allow for that extra pressure from the air expanding.
ive been running 44psi cold in my 235/45/18 for more than a year. my mate that worked for dunlop said it would help with tyre wear and he was right. when running 38psi the inside edge of the tyres would wear out cos i was out of adjustment for camber. so it does help with tyre wear. but as others have mentioned it will effect grip. which isnt a big deal for a stag on the street.
My local Bob Jane recommends 34psi all round.
And my ex tire fitter mate recommends 38psi all round.
If I'm road tripping I'll generally up it a bit more to 40-42psi or so.
all driver training companies strongly recommend to drive 40psi (yes even for your daily)
The more pressure allows the tread patterns to open up which helps when driving in wet. Also there is less flex in the sidewall which reduces heat and wear on the walls. It also provides more control as the tyre isnt rolling over itself when you make a turn.
Old cars used to have 30psi due to a lower pressure provided a more comfortable ride. If you look at the new holdens/fords ive been told they will recommend 38psi due to advancement in suspension to provide a softer ride.
38psi-40psi is the recommended tyre pressure.
/source: Driver Dynamics
you can probably run higher pressures now due to and advance in technology and materials too
That's a pretty blanket statement.. it really depends on size, profile, suspension setup and use.
The pressures I posted above are what I have found to be the best in my situations.
Experiment people, don't take anyones words as gospel.
I had the same recommendation when I did my driver training course in 1999 with Ian Luff. The idea being better wear and helping with braking around corners, or something like that.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
