Hi all!!
I just found out about an adaptor kit that changes a standard H box to sequential. I have emailed the manufacturer and am waiting for more info on costs, availability etc, but just wondering a) if anyone has heard about these things, and B) If I can get them at the right price, who'd be interested???
Thanks
I have heard of plenty of ‘off-the-shelf’ GTR sequential boxes – but not of a sequential conversion kit (not for the GTR that is). I’d say it would be quite expensive considering a new sequential box is upwards of $20k. You’d probably need at least a new gearkit/selectors, shifter mechanism, levers, etc. maybe even a new clutch, to modify a standard box if it is even possible. Then you’d probably want to add hydrualic actuation, paddle shift, etc so you can be just like Schumacher. But if you have the $$$...
Japanese company "Ikeya Formula" make them...
R32/R33 GTR kit retails for 150,000 Yen.
R34 GTR Kit wasn't released last time I heard
All GTS-t kits are 120,000 Yen.
It's just a dumb "Japanese innovation" guys... It sits on top of the standard box and it's ugly as all hell.
Not even the japanese buy it for their cars. I played with it at Tokyo Autosalon last year and it seemed to work okay, and a cool gadgety "novelty" item, but I sure as hell wouldn't put it in my car :D
Here's their website: http://www.ikeya-f.co.jp/english/
The biggest reason why pple move to sequential boxes is to enable faster shifts.
Ikeya Formula sits on top of the standard box so the speed of your shift is still fundamentally restricted by the design and internals of ur own gearbox. It just changes the h pattern shift to a sequential pattern. You can argue that yanking on the Ikeya formula is slightly faster than shifting your H pattern gearstick, but eventually the weakness of your box will lead to its failure.
The Ikeya looks like puss, I have to say, but it is not the one I have been told about. I can get the Holingers for $18k, and HKS for even less. I've heard about an adaptor and is fitted to the standard shifter with out the ugly mods of the Ikeya product.
Still waiting for info to come to me, but it is selling really well in the USA to Supra owners for about $500 US + fitting.
Apparently there is a locating dial placed around the shifter that is twisted to choose either standard "H" pattern, sequential or Drag shifting. I am trying to wrap my mind around how it actually does this, but I willpost more info as soon as it comes to hand.
If it is an external bolt on adaptor, then you are missing the point of a sequential gearbox - your shifts may consist of a simple push/pull motion, but the adapter mechanism itself is still going through the motions of your H-pattern selector (probably through some complex little gear/linkage setup thingamajig). In essence you're just adding more slop/compliance/weakness into the system for the sake of lazier up/down shifting. Unless you're particularly challenged when it comes to shifting up and down a H-pattern, I don't see how a device like this could be of any real advantage past it’s “look at me im a racecar driver” novelty factor.
Yeah, I see your point, but if someone doesn't like the novelty factor, why do they buy a turbo car and put mag wheels, exhaust, BOVs etc on it??? Sure, there is the performance aspect, but don't these cars go fast enough??
I personally don't like the paddle shifters in the Ferrari's, but people buy them. Why do R34's have this feature on the steering wheel??
"BECAUSE PEOPLE WANT IT".
Everyone in real life I have mentioned it to has gone "cool, I'd buy one!!" Looks like most of those people like that novelty factor - otherwise they'd all be driving 3 speed auto corollas that get them from A to B, wouldn't they??
Information just to hand...
"The shifter is comprised of a set of guides.
What happens is you engage the device and it sets
down a guide 1st through 4th gear. Once you disengage
the mod you drive normally. It is not a true
sequential shifter in the forwards to back pattern.
For that you'll need a true (and expensive) sequential shifter
which is very costly. The adaptor works really well
and since installing it I've never missed a gear while
drag racing."
Waiting on more info & pics, that I will poston receipt
Iyaya...
I *had* that Ikeya Shifter on my site, but after Ikeya went through their 3rd generation make-over for it, I got a bit suspicious about them... good idea if Ikeya actually open up a branch in Australia to handle all the warranty work....
If the above conversation is still about the ikeya shifter then i can gurantee you will still experience missed shifts if u shift too quickly.
You are still limited by the fundamental construction of the standard box.
A mate of mine put it on for a while and realised that its not much more than a rice item.
Do u mean to say that you drive an R33 GTR V-SPEC (if you really are) just because of its novelty factor and that your mates think its a sick car?
Usuckpoo (interesting call) you are just not seeing this are you? If you actually read the text on my posts, you might understand what I am saying?? Seems like Ureallydosuckpoo as you are making a bit of a dick of yourself.
I'm not going to be the source of your cheap entertainment. I have more important things to do.
This post was a simple espression of interest, nothing more.
For the record, I own 4 companies and don't suffer fools well. So as a matter of fact, I DO have a real GTR V-Spec, so don't patronise me.
Now, for everyone else who's had something useful to say (that is every contributor to the post except Mr Poo), thank you for your honest points of view and thoughts. I do greatly appreciate your time experience.
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
