I'm not exactly sure how the speedo works in an R32 GTR but I reckon in the old days a cable ran into the back of a cluster, and drove it. My car makes a small clattering noise from behind the cluster when you're at or above 50kmh. A little like when you put a Star Wars swap card in the spokes of your BMX's spokes (yeah, I never had tuffs......) As you vary your speed down from 50 to zero is goes away. If I'm right that there is a mechanical drive back there, then it sounds almost like the speedo cable is slipping where it connects to the speedo. Almost as if the connection had failed and the cable is rotating in the 'couple'. Geddit?
Any ideas as to what it is and how to fix, as it is a little annoying?
All gauges have full functionality, including the speedo. It's unlikely the dash has been tampered with as my car shows 187k klms and import papers verify.
Thanks in advance.
https://www.sau.com.au/forums/topic/324010-r32-gtr-speedo/
ive got this noise behind my dash (i think) seems to come after a mins of driving from cold, will caltter for afew seconds, at any speed, go away then come back, it usualy lasts only few minutes if that, and only started doing so ever since i took my dash cluster out to pull the bloody "hicas" light out...
might pull it out again and put abit of vaseline on the drive that goes into the cluster...
https://www.sau.com.au/forums/topic/324010-r32-gtr-speedo/#findComment-5285997
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
