ok so this is the situation.
this dude i know is nearly finished his r33 gtr im not going to go into to many specifics but its an r33 GTR with a rb26/30 with a to4z making around 600 4wheel kw
i have an r34 GTT with a 26/30 and gt42r when tuned it should have 700hp
now the debate is who will be faster down the quarter mile
both cars are fairly stripped and caged
both cars have dog boxes
both with drag slicks etc
both drivers around the same sort of skill
neither of us will be at the track till around october so i just wanna hear what sau reckons
thanks
https://www.sau.com.au/forums/topic/324034-who-would-be-faster/
  • Replies 160
thanks
Do you mean 600hp or 600kw because i am yet to see a to4z make 600rwkw on what ever fuel.
both will be quick, but the gtr will have the traction off the line, and that makes a big difference.
peak hp is only part of the equation. where each turbo makes it's power will play a big part too because if the gtt has less down low the gtr will pull away off the line even more.
suspension setup will play a bit part as well. if the gtt has stiff suspension (for a track setup rather than drag) then the gtr will pull away off the line even more as it will have better traction. stiff suspension = poor traction.
as a bit of an indication of things, i had/have an old motor magazine where they ran a v8 supercar, a porche 911 gt3 and a formula ford down a 1/4 mile (think it was setup on a runway). all 3 ran similar times (think the v8 supercar was a fraction quicker). the porsche and the formula ford both killed the v8 off the line (had one of the taller diffs in it, plus they are just hard to launch at the best of times). the acceleration times were a true indication of the power though. i think the v8 supercar was a full second quicker from 80 to 120, and the trap speed was much higher on the v8 (was very high for the time it ran)
unless the GTT has a good suspension setup id put my money on the GTR winning as you are going to have traction issues in 1st and 2nd possibly even 3rd gear in which time the GTR will just walk away from you. both cars starting at 100km/h would be a different story though.
You can have the fastest car in the world, but it all comes down to the driver
hay mate
ive had several fast cars and i wouldnt be investing 150,000 into a car if i didnt know how to drive would i
my question was about the cars with equal drivers skill.
marc
ill have some pretty good suspension setup and wide as f**k rims on the back ill be investing heavily on traction and keeping it down as best i can.
mickey thompson drag slicks should be good enough lol.
also throwing the whole nismo suspension arms catalogue at it
lol
i can see it braking traction in 4th gear pretty easily hahaha
Agreed. And to the guys saying an AWD will have a quicker launch, not always. RWD is just as fast if you can get the grip, it's just getting it is not easy. Ask any top end drag racer. They've kept RWD for a reason. If you can put the power down with just the rear wheels, you can be just as quick, if not quicker. Why do you think Top Fuel still runs RWD? It's not for nostalgia's sake.
hay mate
marc
Well if that is the case, looking from a hypothetical point of view, the GTR will win....
hay mate
marc
will it be coilovers with a somewhat heavy spring rate? for drag racing you'd nearly be better off with the stock suspension as it allows plent of weight transfer over the rear wheels. that is where the awd of the gtr gets its advantage. it can run a slightly stiffer suspension and still get off the line better as the front wheels will pull it as well.
to be honest though, i don't think you will know for sure until you actually race. the reason being that while you may be both experienced, how much experience do you got have with cars with the sort of power level you are going to be putting out?
ive got friends who have cars in the 7 sec bracket (not skylines) but from what i can see and experienced dyno figures and the race are 2 totally different things , quoting a friend when i say dyno results mean sh*t! he got really poor results on the dyno then turned it around on the track with times.
like status says the other variables mean hell of a lot , track temp , overall weight of the cars, outside temps, track conditions , the better reaction time..
on paper id say the GTR but only the race will tell.
Edited by Hiroshima Screamer
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
