  • Replies 160
How far away is the race...?
The GTR will be easier to drive than the 34 down the track but thats half the fun.
Only one way to find out...
If the 34 was auto I would say bye bye GTR but the manual will slow things down a little.
Sure there will be dozens of them, but the fastest 1/4 mile skyline in the world right now is a gtst and it resides in England.
Average street car is always going to get its arse handed to it by an awd but a prepped track car is a different animal and I believe that is what the original poster was talking about.
Street car dude, street car.
Biiiiiig difference between a street car and a single purpose, track dedicated drag car.
So going back to the original post, I still have my money on the GTR.
If we were talking 1000HP, track specific cars where the GTT has had all the work done to get it off the line and down the track, then my money would change.
But a street car, on street wheels, the 4wd will overcome the weight disadvantage.
And if you read the thread correctly he mentioned good suspension and the right wheel rubber combination.
Done correctly it will be at least the equal of a heavier gtr.
How do you think the vl boiz run 9/10 second passes.
With 1000hp and a 4 link rear and/or mini tubs, or at least specifically set up for straight lines and straight lines only.
And VLs are generally always going to be faster, mod for mod, thanks to a live rear and more cubes.
could be. or just utter b s
yeah sweet ... f**k off
im well aware of the differences, on the strip it will have drag rims and micky thompsons, still working out suspension atm. gotta finish the engine and body work first mate
agreed
my car has a 3liter bottom end mate
I'm talking about 3 litre bottom ends with single cam heads on street cars mate. do some research.
As im sure you are aware, it basically comes down to how well you can get the rear end to work, if you can get it to hook up, then the weight transfer will take over, and you will be home set, as long as the toe and camber can be controlled at maximum squat, and the gearchanges dont upset it too much. Good spring/shock matching are crucial in this area
I don't need to do research. You asked how the VL boys do 10 seconds. I answered.
There's no substitute for cubes. Shoot for straight out HP and an RB26 will struggle to match a single cam RB30.
agreed
All of my comments were in response to FineLine.
If you are going to really start setting your car up for straight lines and straight liens only, then my belief that the GTR will be quicker may change. But if both cars are to remain fairly "streetable" then I reckon the GTR will still have it. All (generalisation) the really, really fast streetable Skylines are GTRs (yeah, yeah, bar a select few RWDs but my point stands).
  • 4 weeks later...
The only way your gtt will do a quick time will be if it has an auto behind it with a decent converter.
We can all praise the VL's but these cars that are running 9's are built with monster autos and might i add a decent squirt of gas off the line.
If both cars are manual, no question its on the GTR.
Except sitting there on the trans brake getting boost going for 10hrs before leaving the line :P
I still to this day admire Haddad & similar people...
The guy drives there with his 900-1000hp ~1600kg Monaro that is quieter than a corolla - runs a 9 sec pass off the tree - drives home all on legal radials :D
You could drive the thing around the corner to the milk bar and never think it was more than a clear bodied factory car (except for that little S/C whine)
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
