Hey boys,
Just want to get your ideas i am looking at getting a ute right, but the bloke said his split up with the mrs and he is now in UK. Now i have done a revs check on it and its all sweet but the thing is he wants a deposit of 35% from a $25.000 sale i know its like around 9g's. The question is he wants me to do it through western union money transfer i have the details and his name and i tried to ring the contact number his given me and its saying its disconnected so i emailed him and asked for another contact number, i just want your opinion guys on whether his legit or a shonk
let me here it!!!!
https://www.sau.com.au/forums/topic/324068-problem-picking-a-shonk/
Holy S#%t!!!, thanks joelymoley appreciate all your guys help :nyaanyaa: and thanks again for all the boys who put their opinion in its sure turned to the other side of the story now he can go shove it..AWWW well what do ya say spend a few thou on d gtr now that makes me smile :nyaanyaa::wacko:
When I was purchasing my bike recently, a mate at a dealership did a 'vcheck' for me (he said it usually costs around $30 but I got it for nothing), apparently it checks that the vehcile has never been written off and it covers the whole of Australia, he also said to do a revs check to make sure theres no encumbrance and revs will only tell you if its been written off in NSW. So anyone thinking of buying a car keep that in mind.
    • Haven’t had the chance to drive it yet with work being a nightmare, will definitely be doing that at some point this week. got these so that grip won’t be an issue at roll racing
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
