The last few months I've been having dramas with the 4wd.. Most of the time's I turn the car on the 4wd/ ABS lights comes on & stays on (rear wheel drive only).. I drive the car around for 30-60 minutes turn it off & back on & the lights disappears & the car functions properly (4wd works).. It does this like a pattern, one whole day it will be in Rear wheel the next it will function properly.
So far I've only checked fluids & searched for tampered wiring... I've tried searching similiar topics but im yet to find a thread which succesfully diagnoses the above mentioned symptoms..
Thanks in advance
https://www.sau.com.au/forums/topic/324079-r32-gtr-4wd-problem/
Did you fit heavier power and earth cables for the relocated battery? Skylines are notoriously sensitive to voltage (or lack of it). You may be draining too much power through a "small" cable during the start process, which requires a large recharge rate to get the battery back to "normal". The ECUs see this high charge rate as an error, and pack a wobbly.
When you start the car can you hear the 4wd pump priming? Mine takes heaps longer when its been sitting for a while. I tried to bleed the system but didnt help. I think the pump is on its way out.
With this said, yes I believe it is the 4wd pump (near abs?) which takes a good 3 seconds longer (going by buzzing sound) to prime then my 2 bosch 044's .. Are you having similar problems with your car? What are your plans
I'll have to look at the car to confirm but from what I remember the cabling didn't look "unusually big", what sort of cabling is acceptable?
edit; come to think of it mate, the car usually starts up & gets the 4wd & ABS light.. After I drive it round for a bit (charging it up like you said) & then turn the car back on it'll play ball & function normally.. Does this sound reasonable? How would i go by resolving this problem as im not very brainy when it comes to electronics.. thanks
Edited by Tomek
when my 4wd pump primes, either first thing when i start the car, or for 1 sec or so while driving the car, the hicas light comes up on my dash, and steering will go stiff for that brief second. soon as the priming stops, hicas light goess off everythings normal....very weird
oh yeh and i noticed the lights dim ever so slightly when it does so
:S
Last few days in my GTS4 the AWD light has been off, and when it kick in the slip light comes on, acting as normal.
Start the car later in the day and back to its old trick of the AWD light being on, the AWD still works when the light it on.
I can here the pump in the boot buzzing on start up, and the times the light stays off i hear the pump buzzing as the light flickers then stays off.
Also anyone have problems turning tight circles and out or parks ect? It the AWD, it feels like it gripping and it shudder the car slightly untill i straighten the wheels up.
Ive had it looked a few times by different mechanics, no one can find a problem.
Yep tight circles and reverse kerb side parking it abit hard, 4wd sends torque to the front wheels and the car shudders. I think the hicas is turning the rear wheels at low speeds and it's dragging the rear wheels while they are turned. That's what I think anyway, I'm gonna install a hicas lock bar, hopefully fixes this prob
Shudder while turning tightly can just mean the LSD is tight (which is a good thing!). I didn't think that ATTESSA put any torque to the front in that situation. It *should* be smarter than that.
i can actualy see the torque needle flick up while doin a reverse parallel park, or 3 point turn lol
then again i got an aftermarket steering wheel (nardi) and if the steering is slightly off while driving, i cant put the indicator stalk left or right....seems like the steering angle sensor is out, how the hell do you align it up properly?
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
