Hi Gay's! I need a full wiring diagram for my HR30!  I have no lights on head lamp, no meter and gauges illumination, and my heater no flow!
I buy my car with replaced wheeldrive on a left hand and wrong stretched wire cable! Can anyone help me???? :wacko:
Cheer's  :nyaanyaa:
P.S. Sorry for my bad english!
https://www.sau.com.au/forums/topic/324137-hr30-full-wiring-diagram-needed/
Cheer's :nyaanyaa:
well you may want to refer to us as guys and not gays lol...
but in all seriousness it may be hard to find
you can try www.Fj20.com they do have some skyline diagrams but are in the most part DR30 specific
other wise google and if your lucky someone on here may have one
Ooh sorry for all! I made a mistake!
yourve posted on every datsun/skyline forum.. lol
I do have a workshop manual... but heck its alot of pages mate
I have about 5 of them plus a couple of supplements for the S2 version and Stagefumer is right, it's a lot of pages to go through.
D
I have a complete original wiring diagram for the HR30 to Japan but she is too old and has a couple of gaps on this, I can not restore the wiring.
I found the illumination diagram here on the forum, I need a lighting and Heater diagrams!
Stagefumer I saw your topic on Japanese Nostalgic Car, nice ride mast be when you finished, good luck!
thanks mate :P
  • 1 year later...
Hello everyone! Have the same problem with wiring diagram. The scheme, which have Koozia can't help me :( I replaced on my C211 ECU from original to HR30 L20ET to install intake manifold, distributor and turbo. So, connect all what I can to car electric I started engine, but not satisfied how it works. RPM limit is only 4500 rpm. I connect only wires underhood in oval plastic. Other is not connected.
  • 11 months later...
Hi...i have a simple question i hope you can help me...how many wires does a L20et TPS have? mine has 2 wires but I found the original L20ET wiring diagram and it shows me 3 wires, the 2 wires are wired correctly to the ECU which is pin 25 & 18 the other is 20 but it doesn't go the the ECU it goes to some other jack, can't figure out what jack though, because the diagram is in Japanese.
I have the original L20et diagram if anyone needs it, but can anyone translate it to English?
Edited by brandy93
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
