Currently looking at my options, one of them being selling up and embarking on the well-trodden import journey. But is it worth it?
This is one of the better looking deals I've recently come across. Have seen simular cars with a set of Watanabes advertised for 9k AUD in Japan :wacko:
http://www.google.com.au/imgres?imgurl=htt...lIcuHkAXd87zWDQ
Assuming there is no hidden rust problems what would this be worth complied in Australia?
https://www.sau.com.au/forums/topic/324140-what-would-this-be-worth/
Whatever it costs you!
If you want it, you gotta pay for it & I think the one you just bought is going to cost you a bomb to get it up and ready for driving.
Give you some idea, I have spent near on 20G's on my 2 cars in last 3 months including purchase of a trailer.
So! It's 15G plus as far as I would think. Only problem with that sort of money is, you're NEVER going to recoop it, not ever, these classics are your passion or nothing at all.
Cheers, D
I thought about importing a hr31 but it wasn't worth it money wise, end up costing atleast 2-3k more then if i bought one here in aus.
If you really want to spend around 14k then buy ravenoaks dr30, prob the best dr in aus.
That dr30 you showed us would be around 12k after compliance, reg and everything else.
Edited by eightsixboy
I was thinking closer to 10k than 15k complianced on road.
The coupe is a solid car, If I spent money respraying and rwc I'm sure I could re-coup most of the outlay but but as i write a tidy iron mask sedan or FJ20 datsun 1600 in the country is looking more attractive.
Thanks for the PM R34, was a helpful insight.
If your going to the effort to import, you'd atleast bring over a coupe :D
fj 1600, worth about the same price, even then the rear 1/4's would possibly be full of bog.
Tough decision, I say carry on with the current project and actually complete it :banana:
and actually complete it :)
That's a very good point guys.
Maybe you should complete something you start for a change. It's my understanding from people that know you better than I, you have never completed any project you have started.
I can tell you, the purple DR you sold me was one of your biggest mistakes and here you're at it again.
I made a comment when you bought this latest version, that I would probably end up owning that too and now, if it wasn't for the PNV in ACT going up on ebay, it may have easily been true.
Get into it and finish the project you have started and then you will understand first hand what the passion costs.
D
D
now thats a good slap in the face if ive ever seen one.. :P
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
