Got the car when it had 68,000km Fresh from japan, now its 116,000kms Ive also done the 100,000km Service, On top of all these mods bellow,
Type B Tomei adjustable Cams ( Cant remember the measurments, but they are lumpy on idling)
Tomei Dump pipes
Sard 720cc injectors
Sard intank fuel pump
PFC
Z32 AFMS
Air pods
Garret -5 turbos
Fuel Regulator
Greddy Boost Controller 2 profec B
Oil - Air seperator catch Can
Xtreme Single plate Heavy Duty Clutch
Os Giken 5 gear set
Alluminium intercooler/turbo piping
Oil cooler
Spitfire coils
3.5 inch exhaust
600hp rated Cat convertor
ALL INTERNALS ARE STOCK
Now long story short I got a tune done but little did the the tuner know there was a rip in one of the hoses this was before i got the piping done, So he set it to 15psi and the car was doing 316-320awkw, He pretty much tuned the car around the leak and everything looked fine, after i got the the pipiing done the car went quicker id say the boost went up automatically, must of been all that extra air going to through. Since then i have taken it to the tuner, his played alittle with the mixtures and so on but didnt touch the boost assuming its where he left it, he was pretty happy with everything, VERY little Knock. I checked the boost recently cause i found out how to and it peaked at around 21psi And now id say its 350awkw-360awkw.
Is this bad for the car? because its got stock internals how long roughly would will she last with all this beating last time i checked the compression was around 165psi on all cylinders. that was at the 100,000km mark.
Edited by GTRAAH
https://www.sau.com.au/forums/topic/324144-is-this-bad-for-my-car/
with a good tune there is no reason a street driven RB26 cant last a while @ 350rwkw
BUT
imho you should re dyno it and have the boost set where YOU are happy with and have the power level that YOU are happy and confident with.
edit: when this happened to me, we fixed the leak and my tuner didn't even finish 1 pass as he noticed the boost hit 26psi and was still climbing.
run was pulled and boost was re-set
make of that what you will :wacko:
BUT
Im definately happy with 21psi but i feel that it might climb alittle higher but nothing past 22psi id say. But if i set it to 21psi i want to keep it around 3-4 yrs before i do my Internals Etc So i want it too last for that long
Edited by GTRAAH
well im saying 3-4 yrs time i want to rebuild the insides i only drive this car maybe 2-3 times a week, Sorry i forgot to tell you all its not an everyday car as in im not boosting all the time PLUS its my weekend car, Does that change things? i want it to last 3-4 yrs healthy before an internal rebuild, And i have just talked to the tuner and he stated that it wasnt pinging or knocking on that PSI setting
Edited by GTRAAH
its hard to say what is safe amount of power as ppl with stock engines have had to rebuid as well.. generally accepted with more boost on stock internal GTR, its good to keep it around 300kw mark to "prolong" its life.. its no guarantee but perhaps better odds than pumping out another 30-50kw and placing more stress.. also if your tune is good and u look after it well, no reason it wont last the distance, but sometimes luck of the draw
Thanks BWRGTR, Is there anyway to keep an Eye out on the wear and tear?
Used oil analysis is the only way I know of. Basically, every oil change you send off a sample of the oil to a lab and they send you a report. Its been discussed here before so search if you're interested.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
