As it says guys i want to check an engine no. out of a R32 gtr to see if it a later model with the long snout crank.
Its a push type gearbox
I'm not sure but didn't the later ones with the push type gearbox also come with brembo too???
Anyone who can help me pls pm me.....i will give u the number
Thanks
https://www.sau.com.au/forums/topic/324171-nissan-fast/
don't think you can check engine numbers in fast. pretty sure it is only for vin numbers to see what year and model the car is and what standard equipment it came with (colour, auto or manual, engine size and aspiration, etc). never seen anything in there about engine numbers though.
https://www.sau.com.au/forums/topic/324171-nissan-fast/#findComment-5283094
Use this file to compare engine Make numbers...
Found it on the net awhile ago.... 1994 model GTR's usually have their engine numbers in the 4XXXXA's. (Going off my engine vs this document).
1993's usually in the 37XXXXA's i think... but its from 93/2 that the long crank started....
RB26_Information.doc
Edited by SideOn
https://www.sau.com.au/forums/topic/324171-nissan-fast/#findComment-5283116
Thanks
EDIT....
My bad.... Its a pull type gearbox.
and the engine number is 039xxxA
https://www.sau.com.au/forums/topic/324171-nissan-fast/#findComment-5284824
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
