Hi,
I have just installed a 3inch turbo back exhaust on my r33 gts-t. The dump pipe is a single 3 inch bellmouth type. really happy with the results!
however the stock heat shielding all had to be removed.
how effective is this heatshield and how much will it affect engine bay temps by not having it? significant power reductions?
wanted to know what people have done (with pics if possible) to shield the standard turbo combination?
thanks!
https://www.sau.com.au/forums/topic/324176-heat-shield-ideas/
Hi,
thanks!
Apparently it can be put on but its a bit of a pain. They did the same to mine when i had it installed...
I had some electrics nearby that became extremely hot and the plastic began to show signs of it melting. Not good.
In short i had one made up.
Repco sell this flexible ACL heat shield material. About $45 for 2.0mx0.5m approx. When I went in there no even knew they stocked it. Its great stuff, easy to form into any shape.
http://www.aclperformance.com.au/prod_heatshield.htm
That stuff?
Will have to look into it, im about to put a 3540 and stainless manifold on my car and want to make up a heat shield that looks factory and covers everything so they cant tell that everything has been changed, im sure a cop will spot it sooner or later but i dont want to make it easy for em :/
thanks for the replies guys. very ncie engine bay there! I will experiement with the stock heat shield and if I cant get the results Im after ill buy some of that ACL stuff. Would like to get the stock sheild in there only to keep it looking standard if/when I get pulled over for an inspection
Yes, this stuff is very effective....i use it on my VL turbo to protect the fuse box.
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
