Who's up for a /\/orthside Cruise this Friday 23rd Jan ?
Is there a definate time to commence the cruise? I'm thinking about coming along.. Red 200sx/Gold rims.
I think the time is 8:15, Chatswood chase carpark. BTW anyone know which level?
Richard
  • Replies 111
Thanks for the dinner guys!
Sorry about bailing, I hate cruising in the rain and I have to get up early tomorrow anyway...
BOOSTD: Beautiful car mate... Two thumbs up bigthumb.gif
Enter the Drag Combat Show 'n Shine with us! $40 and park your car next to the SAU stand and help us out!!!
SAU Thread: http://www.skylinesaustralia.com/forums/sh...ead.php?t=32281
Drag Combat Website: http://www.autosalon.org/dc.asp
Cheers,
Andrew.
Thanks guys - good to meet all of you !
I agree with Merli - BOOSTD - nice car mate ! Cheers for the turbo tips too.
What happened to Mark & Ken - it got a bit hectic there when we were leaving the car park - I hope everyone wasn't too rushed .......
Thanks for the tyres Andrew :) - did you check the funds ? I'm pretty sure it was right ;)
Thanks B-man, Merli: Had a great night- will have to check out Palm Beach during the day next time. I didn't realise we were driving along the water front until we arrived at the "Summer Bay Car park" I'll be up for the show and shine.......have to get some elbow grease into the black paint. =)
Yeah man very nice, sounded awesome when you went screaming past me on the way back. How was that dodgy overtaking manouver of mine just after that? I had to cane it to get to the gap but when i gave it too much the wheels kept spinning. One time when 4wd would have been lovely to have!
That over taking manouver was pretty crazy! Geoff and I just went....holy Crap. Looked pretty close from our perspective. We kept getting wheel spin in 4th if I kept my foot into it after 5500rpm....so I short shifted to avoid any side window driving...hehe
Yeah it wouldn't have been a problem if the road was dry but when I saw some light coming over the top of the hill I put a bit more into it and the wheels started to spin. You pull out knowing you've got the power but getting it to the road is another story.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
