Hey guys i got a new turbo internal wastegate , now i was just wondering whats the best way to control boost? i want to hit 17-18psi max the turbo is a highflow 3576 with a .63 rear housing. Now i have a high pressure actuator on it and when i flloor it it hits 18psi , and also my Greddy EBC profec spec B-II is connected. Should i remove my ebc? and just let it run with the actuator? what is your advice? not really sure what i should do before i get my tune.. cheers
Geraus.
https://www.sau.com.au/forums/topic/324215-best-way-to-control-boost/
if yor profec b isnt up to the job. you should look at the jaycar iebc. i know with a lot of IW turbos, thy hav a drop off in power at higher rpm. the jaycar item allows you to have two boost maps. those maps are fully tuneable allowing you to open/close the WG in small increments when you want. so you can close the WG slightly at the higher rpm to keep that power curve nice and steady. for eg. you can have a wet wether map set at say 10psi, you can tell it to start opening the wg fairly quikly, thus slowly building boost to stop that insane wheel spin in the wet.
you can also have a hi map set to 18psi, keeping the WG shut as long as possible to bring the boost on as quik as possible, then slightly shut the WG at higher rpms to keep that curve steady.
food for thought :cool:
turn the profec off and drive without it doing anything. if it makes boost the way you want it to then yer remove it. if not then use the profec to adjust it, they take a bit of getting used to but they're a good ebc
hmm alright sweet, but i set my greddy profec spec b to 14 psi and it doesnt go to 14psi... it just goes straight to 18psi... does that mean i need to adjust my actuator?
Edited by geraus
Sounds like you have a 1.2 bar actuator?
If so you will never get boost below 18psi (or close enough) no matter what boost controller you use...
Controllers can only raise boost above levels set by the actuator, not lower
I'm in the same boat, got the hypergear ATR43 with high pressure actuator.
I took at least 10mm of preload off it, now it has only about 2-3mm pre-load. It holds true untill boost gets to around 15-16psi then opens.
I also run a greddy profec II but it pretty much isn't doing anything, set on "low" at 0% lol.
Unfortunatly untill i re-do my intake (pod and afm to turbo) i can't hold that boost till redline :)
The boost controller can only rise boost. it can not drop. So if the actuator’s minimum pressure is at 1.2 bar then the minimum boost level can get will be 17psi. Also if your turbo's got gate controller installed then you might want to lose it up or adjust it abit. That sits your final boost level even you have no actuator.
Its in hypergear's thread. Stao updated it few times, the current one holds boost pretty well. He's using the controlled creep method bringing boost up without drop to 7000RPM. Very smart idea, It worked pretty well. I think its a separate apartment from the actuator, it seems like you can always get to the set boost level even the actuator is removed.
Ie if I set my boost level to 18psi with the gate controller it does not matter what I do to the actuator it will always creeps to 18psi. With actuator I get 18psi by 4000RPM with out I get 18psi by 7000RPM. But you can adjust it to set it at what ever level beyond the tip off level with the actuator.
Edited by kwickr33
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
