Have some bits and bobs from my R34
Nismo coilover's, need a rebuild $200, these were awesome when in the car.
Stock R34 Radiator, recon'd about 10,000km's ago $150
Stock R34 sedan spoiler in black $100
2 x stagea rear door's (complete) $50 for both
2 x stock R34 auto's, one has done 170k's (slips a little 1st to 2nd when pushing it) the other 70k's (drove perfect) $100 for both, wont seperate, yet to pull one out.
Stock RB25 intake pipe $25
Pod adapter and cheap pod to suit RB $30
Stock rear camber arms to suit R34 $20 pr
Stereo brackets to suit stagea $20
All parts located in Bunbury WA, will post at buyers expense.
0419943997
https://www.sau.com.au/forums/topic/324219-r34-bits-n-pieces/
hello .... you also have the original wheels of the R34? to be clear 18 "/ 9"
Your after R34 GTR wheels by the sounds of it.
Sorry no.
Also have a stock RB flywheel $25
  • 3 weeks later...
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
