hmmm interesting....
so all i need is r32 fronted rotor, caliper each side and 300zx rear end rotor and caliper and then i just change them over????
is the jobe easy enough to do yourself????
do u have to get approval from transport?????
sorry bout all the questions but is very intresting to hear.
Dan
:wassup: :wassup: :wassup: :wassup:
dont worry about your diff.
mine has survived a HARD 12 months at the drags... drifiting... all sorts of diff bashing.
Een got a busted diff mount and the thing aint hicc-uped :D
reminds me... gotta fix the mount in a few weeks too.
But get an RB30 radiator if you change. Much better than the Jap spec.
And as for waiting for th motor, and doing suspension etc first. GOOD CHOICE.
better to play with brakes/suspension etc, and get used to the handling before getting more power.
Much safer and smarter.
Does anyone have any idea's for suspension for an import r31 coupe??????
it has the adjustable sus in it now, that came standard but i dont think it works anyway.....
maybe just go some sports suspension or something...
Dont know to much bout suspension
Dan
:cheers::D;)
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
