whats your experiences with TO4Z , I'm thinking of getting one and I've been hearing different things....
I'm chase a turbo for 600+rwhp with as good a response as you could expect, which rear housing.. etc
theres million different TO4Z's, .......... on a 2.8L with 272 jun 10.8 cams which one ?????
I've been reading the dyno threads etc but not everyone says what TO4Z they are using ??
https://www.sau.com.au/forums/topic/324242-to4z/
There isn't a million.
There are two.
One made by Garrett, the other by HKS.
Then there are .82 or 1.06 rear housings that are used (HKS's variants IIRC are slightly different)
HKS items also use anti-surge front covers.
That's it. If you want 440rwkw+ - its a 1.06 housing.
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5284365
Hi Richard,
Go Garrett. You should also get in touch with Brockas as his is making around 586hp and that's still a 2.6.
I'd start off with the .82 housing to get the best response possible. Well that's what I want to put on mine anyway so would be good to see how it performs :banana:
No luck with rebuilding the turbonetics or just too costly to do?
Cheers, Jon.
Edited by jonn
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5284402
Hi Richard,
Cheers, Jon.
Ha Jon, can rebuild the turbonetics with a new oil and water cartridge for about 1200, but thought that might be a good opportunity to change, seen some good results from the TO4Z'S @ OR AROUND 600RWHP, I think thats about what the turbonetics GT-K850 was putting out at 24psi, and maybe better response from the TO4 !?
either way you'll see it next track night :D
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5284591
A HKS 0.81 to4z will go over 450kw, mine made 605rwhp (i think thats around 463rwkw) on only 21psi on 98 pump fuel. Others with garrett 0.83 versions have also done the same and better with more boost.
I agree, I went down from the 1.06 to the 0.83 and made the same power (599rwhp).
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5285883
thanks for all the input guys, looks like theres still some debate over rear housing sizes and what they are capable of ??
there seems to be quite a few getting 600rwhp from the .83 garrett, so I'm inclined to try that first..
If it doesn't come up to the mark is it as simple as just changing the rear housing to a bigger one ??
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5286065
The facts are that the T04Z's marketed by Garrett and HKS use the exact same cartridge or center section and wheels .
The only difference is that Garrett's housing are generic diesel engine ones where HKS's are petrol performance ones .
The compressor end one is port shrouded so that users can get away with using "response" sized turbine housings on petrol engines and not get compressor surge . From memory HKSs turbine housings are T4 international twin entry mount flange but only have a single passage or scroll within the housing , no doubt its made of some high nickle content iron to cope with high petrol engine EGT where the diesel truck housings are not .
I know people use T3 flanged , T3 Euro flange , housings made for T4 turbines such as the Z turbos P trim but its probably not the way to get the best out of them .
Given a choice the GT4088R is a more modern unit but the word on the net is that some BWs may be better again and cheaper in twin scroll .
Cheers A .
Edited by discopotato03
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5286155
Paul what was the response like with the smaller housing?
Just a thought Richard does the Turbonetic and Garrett T04 share the same flange size or will they be something completely different?
Edited by jonn
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5286211
Cheers A .
Ha Disco, so you reckon the GT4088R would be better at that power--any examples
All this compressor size A/R ? rear housing,, etc etc .. is making my head spin, I just want someone who knows there shit ( about turbos ) to say " for that power with good response you need #### turbo"
even the workshops I've spoken to contradict eachother ??
for those reasons I'll probly end up with a "stone age" TO4Z, because at least I can see some good results in the dyno thread.........
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5286274
garrett t04z with a 0.84 split pulse rear on a 6-boost divided t4 manifold and at least a 44mm external gate
will make between 570-630rwhp at around 24psi
full boost in 4th gear between 3700-4300 on 2.6l
expect a little better response and power on a 2.7l :P
Edited by Cerbera
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5286301
yeah its a 2.8L :rofl:
those figures look spot on ! thats nice response for that power--
might lose a bit with the manifold, think its a X-force, but have big external gate..
how much difference would the 6-boost make ? and how much $?
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5286351
Hi Jon, yeah I can get a TO4 with same flange etc so i shouldn't need to change anything, the rear is, I thing its called V band, anyway everything should match up.. it'll be a good test mule for your setup :P if you decide to change...
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5286563
I think you need to decide exactly what power level you want and size the turbo/s 10-15% above that .
I personally think a GT4088R is more modern wheel wise than the Z turbos older T series wheels but the GT turbo is also more expensive .
On an RB26 head I'd look at it like this because this is where the equivalency lies and response can be won and lost .
Std an RB26 is essentially a twin scroll turbo engine that has two scrolls and two waste gates , they happen to be on two individual turbochargers .
To emulate it with a single you again need two scrolls and two waste gates because there is no other way to divide the pulse energy of the front and rear groups of three cylinders .
You can put a single turbo and gate onto it but doing that basically means you're forsaking the low end for the top end and doing it with a lower budget . I really wish people could forget about Hp/Kw numbers and concentrate on torque numbers and the spread of torque .
Anyway what can you afford to spend ? Big twin scroll singles with divided manifolds housings and two gates can help you make big numbers but with 2.6 litres I think it would feel pretty flat till halfway up the rev range .
A 3L bottom end makes it a lot easier to have some mid range because the engine can make it with or without the big blower on the side .
I'm really beginning to think that dirtman is onto something with the twin GT2871R's (GTRS) because he can use a lot more of what Nissan gives him on a 26 so the cost of building it should be less .
It would be really interesting to see the torque differences of twin 2530s GT2860RSs and GTRSs on a reasonably well developed RB26 - porting cams and a decent say 8.75-9.0 static CR .
I realise that singles are easier to work around than the factory twin system but if it were me and I had the engine out of a GTR I would be trying to rehash things to make the turbos easier to work around than they are standard .
In any case if you got them working properly there's no need to fiddle with the things so the complexity wouldn't matter so much . Cops would be able to pick any big single on any RB engine .
A .
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5287014
I've driven a couple of twin 2871 setups on both a 2.6L and 3L and was not impressed with the response.
Personally if you want to run a T04Z with a twin scroll manifold I'd go a 1.00 if you want a bit more power, particularly with a stroker, 0.84 for mega response if you're a circuit junkie.
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5287199
thanks Disco
well I have 2.8L to help low down..
as far as budget.. the motor is new and all setup for big single, so thats all I want to do at this point, just replace the cooked one thats on it. I'll look intothe GT4088R, but it also comes down to if it will bolt up to what I already have which is I think a split X-force manifold & about a 4inch V-band dump..
anyway Disco what are the specs on the GT4088R I would be looking at for 600+rwhp + best response ( rear etc )
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5287224
aaaarr circuit junkie :thumbsup:
yeah.want as little lag as possible, some of the events over here ( WA ) are tighter than a #######
:D
https://www.sau.com.au/forums/topic/324242-to4z/#findComment-5287230
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
