Paul what was the response like with the smaller housing?
Just a thought Richard does the Turbonetic and Garrett T04 share the same flange size or will they be something completely different?
I was disappointed to find that almost no difference in response dropping down the rear houing, so ended up going to a 3076R dropping back to 500rwhp but alot better response.
https://www.sau.com.au/forums/topic/324242-to4z/page/2/#findComment-5288270
500rwhp out of a 3076R ?? sounds like a WA dyno :>
On topic, if you areafter 600+ rwhp, get the 4088r.
https://www.sau.com.au/forums/topic/324242-to4z/page/2/#findComment-5288664
I started a long post but deleted it because I think cubic dollars can go into a GTR and it could still be beaten by smaller lighter cars .
Long story short are you out to win or track a GTR ?
A .
A. its still a street car so I'm not going to bet all the stripped out Evos, mainly there for a bit of fun, but don't want to have to wait for boost out of tight corners...
https://www.sau.com.au/forums/topic/324242-to4z/page/2/#findComment-5288937
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
