Hey guys, i have no idea where to post this. So il have a crack
I have an r34 GTT,now on the back it says skyline as they do, but i really like the big silver letters that say it, and i have them like pressed into the back, the writing is white and the car is white, can barely see it.
anyone know where can actually get these letters and put them in the place of whats there now???
Hope that made sense.
Thanks in advance.
https://www.sau.com.au/forums/topic/324245-skyline-writing/
y would u wanna make the back of ur car look so pox for?
i have a white skyline and it had the lettering done in red when i got the car painted it was the first thing i told the painter to get rid of as well as the boot lock
much cleaner looking
https://www.sau.com.au/forums/topic/324245-skyline-writing/#findComment-5290037
Maybe that's because your car was red and the writing was white?
I think they look good. Especially the silver/chrome look.
I don't reckon it's " Pox"
https://www.sau.com.au/forums/topic/324245-skyline-writing/#findComment-5291396
