Hi Steve-SST, I have never claimed to be "Australias resident Expert", if you read my signature you will note it says..........................
"I don't own or work for a workshop"
"I don't know everything"
Unlike you, I have nothing to sell, I don't have to impress potential customers, I make no money out of this stuff. When I don't know the answer to someone's question, I say so. I have no need, or want, to pretend to have more knowledge than I do. When I make a comment or a recommendation it is from personal experience, not regurgitated from the suppliers publicity.
I think I have made my opinions on dyno comps well known. You and I both know how to "get" a good power reading. It is way too easy to achieve a number for a 10 second power run. It is a totally different proposition to achieving a good set of 1/4 runs or a consistent lap time on the circuit.
I get very tired of guys with excuses when they loose on the track; it was on low boost, it only had premium in it, we retard the timing for the road, we run it rich on the road to save detonation, it had normal tyres on it, the bonnet was closed, I can't get any traction, it's got the wrong plugs in it, it's too hot today etc etc.
The BS stops when the flag drops and there ain't no flags on the dyno, so in my opinion the BS continues there.
  • 3 weeks later...
your right, we in WA are a fair bit behind you guys... our street cars only run low 11's... The old grey r34 ran 11.13, Ant ran 11.4, has Danny's car done an 11 yet Steve?
Thing is, these cars are street driven every day... well, Ant's is street driven when he's not driving the 1600 :-) (400+ hp on the old motor, wasnt it Steve?)
I see one person pushing a barrow.
And another without a barrow to push.
Quite frankly, why on earth workshops persist in posting on forums is beyond me. It makes them look decidedly silly. Right or wrong, it just seems too much like self promotion. Normally businesses need to donate in order to promote themselves on here, steves getting all his plugs in for free.
i think he supports the wa section of the club pretty well and helps out alot of people on here as does sydneykid. only natural those who know the most will clash occasionally, makes it more interesting:) no one else can argue with 'em hehe
Err, back on topic.
If you were adamant about running your car without AFM's, there is PowerFC Pro software available, which instead uses MAP sensors. But, like Sydneykid said, there really isn't an advantage/disadvantage in using AFM's anyway. Huge power figures can be pulled regardless.
PowerFC's have pretty much everything listed in the first post (knock, efi, afm, speedlimiter, timing), with an optional boost controller (either the PowerFC EBC, or the AVC-R). Heck, the PowerFC is quite well known for having great knock protection.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
