You need to cancel your current rego on the car in VIC, and whoever you're swapping your car with, they need to have it re-registered in NSW.
That involves, Blueslip, Greenslip, and a engineering cert if you have engine mods (the blueslipper will pick up on this during inspection)
Edited by Owens
Correct. You can transfer your rego into someone else's name in the same state as you, or transfer your rego into your own name interstate, but you can't do both.
As said, you will need to de-register the car and the new owner will need to go through the whole registration process from scratch.
also, just because you may be swapping cars (with no cash changing hands) you will both still need to pay stamp duty on the value of the car. Can't have the government missing out on its well earned revenue, now can we?
thinking about swapping my car with someone in sydney & i live in victoria, i need to get it roadworthy, does a victorian roadworthy certificate cover NSW? or do i have to travel to NSW & get a roadworthy done?
well most important to keep old rego much ezyier to swap over. then if the car is import then is more trouble there as well aspecialy if is imported under more then 15 yold rule what means u need engeniring certificate in each state as all difrent rules :)
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
