hello
My alternator is making a whistling noise, it just started in the last week. The noise gets louder if i have more accessories switched on eg. lights, fan, rear demister.
Can the brushes in these alternators be replaced?
Could it just be a loose drive belt on the alternator?
should i just get a new one? if so how much do they cost?
Cheers
https://www.sau.com.au/forums/topic/324289-r33-alternator/
hello
Cheers
The whistling could be the belt slipping. Undo the lock-block bolt and turn the tensioner bolt a couple of turns. See if that helps.
Maybe also the bearings are done with life. They can be replaced. Brushes shouldn't make it whistle and yes they can be replaced.
I rebuild them for fun so heres some info
http://www4.wave.co.nz/~lakewood/Skyline/Alt.htm
Yours can be serviced.
Nigel
https://www.sau.com.au/forums/topic/324289-r33-alternator/#findComment-5285254
Nigel
I tightened the belt and it appears to have helped a bit. Still sounds a bit funny tho i rekin i might give servicing it a shot. will i need a press to change the bearings?
I had a look at the alternator it is a Mitsibushi 23100 70T17 90A do you know the part numbers for bearings and brushes?
Thanks
Edited by ForcedInduction
https://www.sau.com.au/forums/topic/324289-r33-alternator/#findComment-5285649
Thanks
Ah sorry not had the 23100-70T17 apart. Mostly I rebuild the Hitachi units. The small rear bearing is the most difficult to get off. I grind the outer bearing ring to allow all the balls to drop out and the outer ring falls off then just use a linish belt to grind away the inner ball race until it loosens and slides off. There is not much room to get a puller around it. By all accounts the front bearing is a slide fit both on the shaft and in the end cover.
Just note the bearing numbers beofre you remove them, any bearing dealer handles them, not just sparkies.
Nigel
https://www.sau.com.au/forums/topic/324289-r33-alternator/#findComment-5286217
