Gtr $182,000?
s15guy
 Share
Congrats on the purchase.
for those wanting to know, the 2011 GTR is still a ways off but will have 15-30hp more, revised aero for more downforce, revised front bar, revised rear diffuser, tweaked suspension. There will be (in Japan at least) another trim level above Premium with many options available such as the ability to option interior colours (not just black or white) and even option on parts from the SpecV range. It will not be called the SpecM as previously thought it has not been given a name yet.
The SpecV goes away next year as it becomes obsolete with all the changes in the base GT-R, and it's possible that the base 2011 GT-R will gain the power upgrade by making the 2010 SpecV turbos standard across the range.
  • Replies 70
Posted Images
Don't you dare show my girlfriend that!  :D
No but I still wouldnt buy that. 1. cant drive that knowing it 'aint a f430
                                            2. Its over 10 years old
                                            3. service costs and parts and insurance!
But still...its a 'ferrari pal!'  haha
Well... I bought the car. I pick it up in about 3 weeks. Excited but also nervous.
Thanks again for your advice guys.
Ill post again when I pick it up Domino.
you will love it mate. basically any car that costs more than a corolla is a waste of money as a corolla gets you from a-b in safety and comfort affordably. but the thing is cars aren't about money. like I said anything above a corolla is basically an emotional choice. so whether is a $50K monaro or a $400K 911 Turbo we do it because whatever the car is hits a button in us somewhere. enjoy it. :D
it's your money mate, only you can justify the purchase
im in similar situation with the gf etc
as long as i have my houses under control, i dont mind making such a big purchase
go for it, and enjoy it, it's a great car.... constantly scraping the long front overhang excluded natch
im in melb, shoot me a pm when you pick the car up, my mates and i are always organising drives up to kinglake, toolangi, mt donna buang etc
hay mate do u know a guy named jordan, drives a bmw coupe?
you will love it mate. basically any car that costs more than a corolla is a waste of money as a corolla gets you from a-b in safety and comfort affordably. but the thing is cars aren't about money. like I said anything above a corolla is basically an emotional choice. so whether is a $50K monaro or a $400K 911 Turbo we do it because whatever the car is hits a button in us somewhere. enjoy it. :)
Awesome philosophy. I agree 100%
If you learnt how to spell and string words together correctly you may understand yourself.
Agreed. But to answer the question...I'm a pharmacist.
Just picked up a white one last Monday. Now for the gruelling 2000k run in!
congratulations.
that run in period should be just about enough time to order and receive a COBB access port and midpipe if you get on and order one now. ;)
congratulations.
that run in period should be just about enough time to order and receive a COBB access port and midpipe if you get on and order one now. :)
Would love to get those things but to find an installer and tuner in victoria?  :)
Who can I trust with my 35 in Vic?
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
