There's three settings on the Bee*R limiter isnt there?
What do each of them minipulate?
there is a red dial(rev1) white dial(rev2) thats for ya handbreak
and a yellow dial which is a gain dial
GTS4WD do a search there is heaps of info on them
as far as a safe guard im not so sure, they should have called them a Bee R oil pump breaker, as if ya abuse them thats wat they will do, not to mention ur standard, if ya running one, turbo also will enjoy the extra heat running thru it
there's a DIP switch on the back that controls what engine it's supposed to work on.
It basically dumps unburnt fuel into the exhaust manifold, which explodes due to heat, which makes the turbo keep spooling. So if you're running a sleeve bearing turbo and run a Bee*R rev limiter, you can kiss your turbo goodbye. For that matter if your oil/water supply to the turbo isn't up to scratch most turbos will cark it... as will any catalytic converter/muffler you try to use, straight pipe or GTFO.
As mentioned above, best thing to do with one is to bin it. Creates more problems than it solves.
had a Bee*R rev limiter strapped briefly onto a RB25DET with a TD06-25G hanging off it. but a gizzmo launcher, no idea. Does it use the same principle? Cut ignition and dump fuel?
Surprised to see so many bad thoughts of the Bee R Limiter.
I have one on my 32R and only ever have it on the low settings.
I would rather cut the ignition on rev limit than the fuel so it gives my built RB a bit of safety on trackdays, etc...
Plus the launch control feature is good for drags.
Haven't had any problems with it with 6 months of use. But as stated make sure you got a straight pipe or your cat won't last long and probably would be good not to crank it right up.
My mate in his 10second gtr also has one and he sits on Bee R and hasn't had any problems.
I ran the Bee-R for a bit on my KA-T setup stateside and on my RB25 for a bit.... if you just set it and forget it, the turbo will be fine. Don't abuse it as stated above. you will go through gaskets fast.
I took mine off of my RB because I have PFC now. using Bee-R as a 2step device is not a good idea...
my installation write up
http://240sxdrifter.tripod.com/writeups/r33bee-r.html
TBH half the reason i don't like it is that it's what muzza's have started using to one-up the age old dose pipe. that's what the kid who bought mine wanted it for... the bangs n pops like he had seen on youtube. not for track use, tried tellin him that it'd destroy hiis turbo/engine. two CA18's later he still comes back to the shop goin "I'm still Bee*Rin it bro".
Lol...
My main problem with bee*r limiters is that so many sites advertise them as an engine safeguard...
For some reason a lot of morons seem to think this means that they can crank them all the way up and sit on the limiter with no negative repercussions...
hey mate
iv hooked mine all up right it flashes at set rpm cut doesnt cut out
yours has two wires at the box..you have cut one
mine has three..grey brown and white
im gona try seperate power and earth to see if that works
but yeah not workin atm so it sucks
yeah the gizzmo cuts ignition and dumps fuel, basically cut all the ign. wires and intercept the signal before the ecu does not cut as hard as the bee r* does...on my 32 gtr can build an average of 16-20 psi of boost at basically any rpm i want, say over (2000 rpm) depending on how i retard the settings and boost settings... Currently running nismo le mans turbos... daily driver as well... plus the gizzmo unit runs with the power fc, currently using a d-jetro...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
