maxim i was interested in that. I heard you had to modify the trans tunnel though or the firewall and this made me a little hesitant.
I have on my onevia with rb20det, 18's, Tein HR's and front and rear strut braces. I found the strut brace really made up for the heavier engine. The rb is great for drifting, i get minimum understeer so its fantastic in that regard. I have a few friends who do some track racing. In the wet weather against a whole lot of other s13's, an rb25 powered silvia had the best time round the track. In the wet.
Anyways the handling effect isn't too bad, and i would go to the extent to say it's a benefit if the car is being used for drifting as it eliminates some understeer.
Turbo tits is right too. Rb25 box bolts to rb26. To do a 4wd conversion to an s13 would be a very big task and i haven't seen it done yet.
Hey Mase,
I don't think modification of the firewall would need occur depending on the crossmember you used. The trans tunnel I would imagine may need some attention such as widening similar to the 'procedure' (hammering the hell out of it) when fitting a RB25 gearbox. The crossmember may need to be fabricated from scratch (Expensive) but I think the dimensions of the 1jz to the rb25 are very similar.
Nothing like a wet track and alot of rear wheel power to put a smile on the dial is there! good times :)
  • Replies 63
max.. u talking about AWD?
No, RWD. Don't think there would be anyway to make a 4wd s13 with a rb or equivlant size engine. No unless you wanted to raise it like 3" from stock!
Speaking of AWD, I wonder if you could drop in a GTIR Sr20 (east west config still ) complete with gearbox and make an AWD s13 that way? Interesting...
true that.. but id rather have the fun factor and no traction than be able to run a good time
this is exactly what i want now
http://www.prestigemotorsport.com.au/au/st...sp?StockID=1084
try this:
http://page4.auctions.yahoo.co.jp/jp/auction/d46228460
ull have to find out the year - with any luck its 88/89 so u can import it. if u get it for 400k yen, ud probably get it here for about 11k $aud, which would be pretty sweet. if u have around 14k all up then it should be fine - the main thing is whether it will be a 88/89 model or not (88 = S63 in japan year system, 89 = H1)
a 26 will be a struggle to fut under the bonnet of a silvia, seeing as though the rb20 basically touches the bonnet. as for a gearbox, you can use any rwd RB gearbox (you could even use the trimatic frrom a VL if you're that stupid), but your best bet by a long shot is the RB25 box (which DOES bolt straight up). you will need to get a custom tailshaft made up, and most likely a custom crossmember. also, you will need to have the GTR front diff cut off the front of the RB26 sump. all your engine mounts would need to be custom made, and it would be a very tight squeeze getting the whole thing into the engine bay. moving the battery to the boot would most likely be necessary.
The RB26 fit's under the bonnet easily, Use standard R32 engine mounts on R32 crossmember, slot the 10 mm to drop the engine a bit lower, the front diff is actually next to the sump and you only need to weld up a couple of holes where the front left driveshaft goes through, as for room in the engine bay there is actually more room width wise in the 180 as they have a macpherson strut front end versus the GTR's double wishbone.
ok i think there is alot of confusion from people in this thread about this topic...
if you have ever seen a RB20/25 vs RB26 - the visual comparison is the fact that the 20/25's have the plenum run over the top of the cam covers and the 26 runs down the side... HENCE - there are no bonnet clearnace issues with RB26
you are correct about gearboxes.. i wouldnt even consider a RB20 gearbox as you'll munch it straight away - so i'd stick with RB25 box...
yes you'll need custom tailshaft.. with my rb25 install i got a custom single-piece talshaft made up $400ish
u dont need a custom gearbox crossmember... instead i used my SR20 AUTO gearbox crossmember and just welded a plate and redrilled a few holes to line it up - simple job
use standard R33 engine crossmember and mounts - its not neccassary to get custom mounts....
and it is a tight fit length wise.. width wise - well if you dont get a custom manifold to push the turbo's forward then you'll be there all week trying to fit the RB26 in with standard exhaust manifolds...
it is not necessary to move the battery to the boot.. as the cooler pipe just misses the battery
hope that clears a few minds up
BRAD
yes it did :D
R31 had a jatco 4 speed, VL had the trimatic.
please don't call me stupid.
since when did the trimatic come out in 4 speed....... all VL Commo's were 4 speed autos
As for the conversion.... its easy as dude. There are a few people here that have replied with facts, but some are just way off track. Traction in a 2 wheel drive RB26 powered car is fine if the suspension/wheel package is thought about accordingly. Understeer is not really an issue either as most will think. Weight wise the SR20 wieghs 140 od kgs with all accessories and the RB ads about another 120kgs to the entire car, lots of which is the gearbox which reduces the talk of underteer to just a rumour......
Speak with a workshop that has done it if your not certain on what to believe in this thread as they will be able to give you 100% facts. Call Dean at UpImports, he is also on here as VSPECV, he has done quite a few of these conversions :(:D
champ... its been discussed plenty of times before...
in all honeslty the weight doesnt effect the drive of the S13... mainly because all the extra weight is due to the large gearbox (which sits close to the center of the car - keeping weight distribution even)
the RB26 (being TT) weighs a bit more than the SR... but not enough to be considered a problem
with the right suspension setup - this eliminates understear caused by extra weight....
hey mate sorry to change the subject but saw the onevia in ur profile, and interested in doing that myself, just wondering about the 180 popup lights, i'm fairly sure they bolt onto the silvia rad support, but what about the wiring for the lifters? is that there or do u have to put it in?
    • If you ask just me you'll get 3 different answers.
    • Do not ever trust ChatGPT with anything math related. They can't do math. They have no idea what it is. With enough data we can fit a decent equation in Excel, or if the available fits in Excel aren't good enough, a Matlab clone.
    • You could check/calibrate that with a thermometer, we have long glass thermometers at work which go from -10 to +150°c, they are pretty cheap too I believe,  as monkey fisted soldiers tend to break them, and getting new ones don't seem to send red flags to the people that hold the purse strings Edit: after a google they apparently cost about $80, but, digital ones seem to be much cheaper at around $40
    • I should have prefaced all of this with "I'd really like to not pull anything out of the car for this"
    • Me, I would happly spend some more coin on better tyres for my street car  Will they work, yes, of course, but why substitute some dry grip/braking distance, and wet weather grip/braking distance on what is really old tech to save some coin on your "precious" street car In the end it might not be you that farks up, it's the thousands of other idiots on the street that you need to worry about  For a street car that gets some "fun time", I have found that a quality tyre that can handle dry, wet, cold (Canberra gets pretty cold) and hot conditions, which may costs a little more, is great insurance  From my experience with them (driving around Goulburn in the winter) the RE003's are pretty poor in cold and/or wet conditions on the street If RS4's didn't hate gripping in the cold I would be running them always on the street,  great in the dry, OK in the wet, but, they do hate the cold, with a passion, I run PS5's year round now, basically, I've found the PS5 to be a great year round street tyre for all conditions, they last well, and are mid range pricing wise TL;DR. Tyre choice is probably like what brand and grade oil you should use, ask 10 people, and get 10 different answers... LOL
