Not really, but i have friends that have mechanical shops, panel beaters... im going to advertise mmyself do good rates etc. This one is non turbo though, its a 5 speed manual deisal, and do they really have problems? if soo then i might have another think about it! thanks Wopred3d, hmmm do u thnk these are unreiliable?>
the only problem ours had was the snapping of studs but that could have been turbo heat related, as yours is not a turbo it may be fine, also this is only one, isuzu are known to make a reliable truck, any jap trucks are usually ok as long as they are maintained properly, how many k's has it done?
400,000 on it .
Oh realy thats a good sign then. thanks man.
Thats pretty low for something that age, ours hasnt been driven for a few years and has around 800,000 on it, we also have an old international that is about to clock over a million and in the 7 yrs i've been there the only major works is a head gasket and gearbox.
  • 5 years later...
This is the first sau email i have had in a while, and its about a shit box tow truck, dam i posted a lot of shit on here.
Hey, it got you back on here! There is a positive out of the spam! :)
  • 4 years later...
Go for it mate, my dad started out unsure like you, now he always tells me 'if you don't take the dive, then you never start swimming.'
You'll start with one, you can work for yourself as a sub to get cash flow and it's like anything, you keep putting energy into something and it keeps growing.
______________________________________
https://www.geelongtowtruck.com.au/
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
