Hi.
I got a problem with the engine only running on 5 cylinders after overhaul. Have changed pistons, valve seals, all gaskets etc..
I did NOT have this problem before.
This is what happened first time when I tried to start it:
- Fuel pump did make strange noises when turning on the ignition, the engine would not start at all, turned out to be the fuel rails connected opposite direction
- After connecting them correctly the fuel pump sounded normal again, and the engine started right away, but it was leaking gas from the fuel pump.
Turned out to be a fuel hose that suddenly cracked and needed to be replaced (fixed).
Now, the engine starts and runs ok, and the gas is not leaking anymore. But the cylinder 5 is not running.
There is spark, but no fuel coming from the injector (plug is not wet and no smell of fuel) :)
The other cylinders are fine.
I have NOT disconnected the injectors during the overhaul.
Things I have tried so far:
Another spark plug and coil (no difference)
Restarted the ECU
What can be the problem you guys think?
I appreciate all the help I can get.
Edited by Iceman22
Gummed up injector. Tap on the body with a screw driver, fairly common when they sit for a while not being used.
Alternatively pull the CAS out, and with a multi/test light verify that no5 is getting correct current.
Thank you for the reply, will test it asap. How do you recomend to clean the injector?
Any more suggestions is appreciated.
Btw, the car was only unused for about 2 weeks..
You can't really clean the injector yourself. You can remove the small top filter and then blow out with compressed air, but that's probably the extent of it.
They need to be cleaned via ultra sonic, and you would most likely remove them all to have this done not just a single injector. If they have only been out of action for 2 weeks, then you will probably get away with just tapping on the body and getting it going again.
If you are concerned about flow pattern etc, that's when you would remove them for cleaning. If it runs fine when you get no5 going, I personally wouldn't bother.
are you getting voltage to that injector? u can buy injector plug testers that light up wen the plug gets a pulse if u dont know how to check it with a multi meter
if pulse is there, change the injector
if there is no pulse, check ecu loom for damage or possibly try another ecu
I swaped the injector that was on cyl5 (the one that didn't work) on cyl1, and the other that worked on cyl5.
Turned on the engine, and the same problem was still there, injector on cyl5 don't let any fuel. So the injectors is not anything wrong with, It must be some wiring that are damaged or not plugged correctly :banana:
Turned out it was 0 compression on that cylinder, now it will be exciting to found out what caused it after removing the head.
When looking through the spark plug hole, I can see that the piston is like new, silver color, while the 5 others are black of oil.
The pistons are new, and I didn't hear any abnormal sounds when firing the engine up, so hopefully the piston is not damaged.
:banana:
I promisied to let you know how it goes.
Well, I removed the head and the 5th piston, and didn't see any problems.
The piston was like new, didn't have any oil on top or anything like the other pistons that worked.
Piston is properly installed, valves are opening/closing and are not looking to be bent or anything. The cylinder wall was also fine (it had good compression before the rebuld).
So I contacted a mechanic, and he said I probably installed the cambelt / camshaft wrong, that caused the 0 compression when firing up.
Do you guys think it's possible to get 0 comp. when installing the cambelt/camshaft wrong? I was making sure all the 3 markings were correct, and rechecked 10 times, and it was OK.
I have really never done a rebuild before so I could do something silly...
Edited by Iceman22
can't see how you can get 0 compression without a valve problem.
and if there was something wrong with the "cambelt/camshaft" it would affect every cylinder the same way.
unlikely to be rings, even if installed incorrectly eg overlapped you would get a little compression.
assuming its a 33 gtst maybe a stuck hydraulic lifter? I don't know much about the hydraulic lifter setup.
I tried turning the engine around with the head on today (cam belt was off). Then I seated a spark plug on each cylinder (one at a time) and tried to see if there were any difference when turning the engine around.
I could feel that there were compression on 5 of the cylinders (more strenght needed when turning), but on cylinder #5 I couldn't notice any difference with the spark plug seated or not seated.
So since the engine block can't be the problem, then it has to be something with the valves like you guys say. Since I can't see any fault by myself then it's best I take it to a professional workshop. Will let you know what the problem is/was when I solve the problem
Edited by Iceman22
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
