hey just chasin front lower contol arms and steering rack im in brisbane happy 2 pay courier costs
cheers ando
Hey mate, i have got a steering rack, yours for $30 plus the freight. Thats the problem though, i am in tassie freight will be the expensive part.
If you get stuck give me a call 0438911374
Michael
cheers ando
Hi
I have both the steering rack and arms in Brisbane
Regards Taylor
0408188777
