Just wanting to know wat kinda response we can get for a cruise on valentines day.
This is not an SAU cruise only as there will be other car clubs involved
Not going for a huge turnout
even something small will be good
might go for a nice cruise down the coast line catch a ferry across the bay etc
Once again we will be filming for some more footage for the Wateva. TV show.
more ideas welcome...
Bring your partners along..
Depending on numbers that we get showing interest will organise the event based around that..also would u prefer a day or night cruise?...
ill put up a few ideas in a poll and see wat you guys and girls think..
You can choose multiple times so make sure u indicate if you would like either a day or a night cruise.
Ta
A.
https://www.sau.com.au/forums/topic/32447-feb-14-valentines-day-cruise/
What about a option of BUSY?
OR maybe not a good idea ??? :)
NAh.. i'll be doing something with a lady no doubt, if i mention car's i'll probably get whipped
Just an FYI though, we got an SAU-GOR cruise a week (or) 2 after that ;)
and not everyone seems to like the idea of valentines day
lol
It's not so much the buys (most sky drivers are)
It's the females behind them :inlove:
:) like i said... im 99% certain that most females, if the phrase 'Let go on a Car Cruise' was mentioned on Valentines Day, the better halves would crack out the whip BIG TIME :whip:
but if your into whips, then it aint so bad :aroused:
lol ya i hear ya
if you got a mrs careful when u mention "cars" on velentines day
valentines day is great for some
personally im over it
if ur partner needs a day to prove to u he she loves u then somethings wrong
you should show it no matter wat day of the year it is
i guess u could always use the line..."but honey how can u make me chose between the two loves of my life"?
but somehow i dont think its gonna get u very far
and most likely end with a slap in the face
lol
well how about for valentines day that you organise to do something down'that way' and cause you have to drive there, you just happen to bump into a heap of other skylines driving as well..just stop for a driving break where the bbq happens to be hehe
thats what i have planned anyways hehe
Hope you feel better ambz :D any chance your keen on helping out with the autosalon this year?? just wondering :)
lols ta
would love to help out again
but unfortunately me is flat out with other stuff this year :)
but no doubt will come down and cheer u guys on! :headspin:
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
