hey guys
before you say, YES, i did do a search, found nothing to specifically help me.
i have a r32 gts-t and the seller, who was a chick mind you, told me its a rb25det engine, series 1 turbo. Now, i know a bit about it and i doubting weather or not it really is because its still a 2.0L 1998cc and only the rb20det came out like that, if it was the rb25 it would be 2.5L. Im pretty stumped so how can i find out what it actually is? Im not a pro at this kind of stuff but i do know a tad.
Also, if it is an after market turbo, not the stock rb20, how much would i look at if i wanted to remove it and how much effort. Being after market it shouldnt be too much right?
cheers
also im sorry if this is the wrong section, i couldnt find any other turbo related section.
https://www.sau.com.au/forums/topic/324487-removing-a-turbo/
I don't get it.
You say the seller told you it had an RB25 and you are saying it has a RB20 in it. So the seller lied to you or didn't know. I'm sorry I just don't get your question? Or do you not know what engine it is?
As for the turbo removal it isn't hard if you are handy with a spanner, why are you wanting to remove it though? You mean so you can change it for something else?
john post a photo of the engine bay
or pm a link to an engine bay photo
it will be the quickest way to work out what engine it has
and then for the turbo do the same
take a photo of the area and post it up or pm a link
there are obvious visual differences between the two (rb20det turbo and rb25det turbo) - regardless of what engine it is on, so it sohuld be easy to pick
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
