done a search on this but havent seen anyone post anything about this topic.
basiclly i have a trust manifold with trust gate. im sure many of you would have a similar setup on a rb25.
but while im dummy fitting it i noticed the wastegate sits stupidly low, the exhaust and wastegate is about the same height. i think this would be a huge problem but i might be wrong.
has anyone modified the trust manifold to make the wastegate pipe shorter? it seems to be a pretty tight fit where its located at the moment.
here is a pic
https://www.sau.com.au/forums/topic/324504-gate-to-low/
Ha ha ha... I would. Especially while you have it out still.. It should be a fairly simple modification, just get the flange re-welded back on by a competant welder/fabricator as the manifold gets very hot and turbulant right there... a poor weld will fail quite quickly.
Bump- Crunch- Woops...
Cheers
Justin
https://www.sau.com.au/forums/topic/324504-gate-to-low/#findComment-5288761
thats pretty normal isnt it, about 4 out of 5 cars ive worked on have trust gateys sitting about that low.
usually s15s but. check out jap web blogs, most of there ones sit that low too.
is that your car in your avatar? looks insane
Edited by hisoka
https://www.sau.com.au/forums/topic/324504-gate-to-low/#findComment-5292958
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
