My tacho one day decided to go crazy, when idling it was sitting around 4000RPM and as soon as I drove off it would bounce around between 7000 and 9000RPM. Tapping the dash behind the steering wheel made the needle fluctuate so it was clear something wasn't right in the instrument cluster. Plugs were all in firmly so the cluster itself was the next suspect. Since I managed to fix it here's what I did:
Start with cluster out (there are plenty of other guides to get to this point):
Around the edge of the cluster you need to unclip the plastic clips (arrows) - there are a bunch of them top and bottom of the cluster, work slowly and gradually unclip them all and the front will pop off. Careful about the reset needle for the trip meter, if you are agro with it you will damage it. Be gentle once you've got the clips undone!!
You should now have a naked instrument cluster (oooh baby!)
Flip it over and undo these 6 screws, careful as when you undo the last one the tacho will fall out.
You should now have a naked tacho module (I'm excited)
Here's a suspect capacitor, looks like it's had better days. It looked suspect, so I changed it. If you change it with the same value you shouldn't have to touch the adjustment pot (right next door). If you do need to recalibrate your tacho this trimpot will let you.
Replace the capacitor with the same value of 15nF (replacement is marked 2A153J - the 153 means 15 with 3 zeros, in picofarads. 15000pF = 15nF). Adjustment potentiometer highlighted in case your tacho is now off - mine wasn't so I didn't have to touch the trimpot (I did anyway, but that's because it was there and I wanted to play with it).
Put it all back in reverse order and your tacho will be less crazy*. I took a photo of 9000RPM for posterity, I hope my RB never actually hits this since it would not end terribly well :banana:
(*statement is true if you have made the necessary prior sacrifices to the skyline gods. I take no responsibility for cack-handed, ham-fisted or butter-finger moves. If you end up in the emergency ward with burns from your soldering iron please tell me which ward you are in so I can point and laugh)
https://www.sau.com.au/forums/topic/324516-tacho-showing-over-9000/
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
