Hi Guys...
Another embarassing noob question here.. :Oops:
Regarding tyres, does the psi required change depending on profile and size ??
For example, i have 235/45 on the front, and 265/35 on the rear (18 inch)..
Should they all equally be inflated same psi ?? Back harder ?? Front harder ??
https://www.sau.com.au/forums/topic/32452-psi-for-tyres/
in r33 it isn't understeer you are worried about though
I run 43 psi all round. Although lower rear pressure will give you better traction for accelerating. Just go as high as traction under hard acceleration permits with your tyres.
Once you go hard enough you may get the occasional chirp as it looses traction over tiny road bumps when accellerating from the lights.
https://www.sau.com.au/forums/topic/32452-psi-for-tyres/#findComment-659520
Hi guys, we run 25 psi (cold) in the 235/40/17 Yokohama A032R's, that goes up to 34 psi when they get hot (after 1 lap). Any more pressure than that and they start to overheat in spots as (being radials) the higher pressure doesn't let them follow the track surface. Since only some parts touch, they get hot and blister.
An extreme example, as the compound is soft, but the same principle applies to any tyre. Too high a pressure reduces the tyres ability to follow the road surface. I would strongly suggest that any Skyline with appropriate suspension geometry, would need tyre pressures in the 28 to 34 psi range on the road. For the track, unless the geometry has been set up for it, adding 5 to 10 psi helps keep the tyre more upright under the extreme side loading you get on the circuit. For the drags I would suggest 5 to 10 psi less would aid the traction for launch.
Hope that helps
https://www.sau.com.au/forums/topic/32452-psi-for-tyres/#findComment-671970
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
