HI all,
I did a search but couldn't find anything related to my question.
Currently I'm using my ipod connected to the bottom 3.5" jack - with VTR2 on I think it is. When I'm in this mode and I've got the air con/fan on I find the only way to adjust the settings for the air con are to either press the off button or adjust the temperature knob to get the control screen to come up.
I'm sure there is another button I can press to bring up the climate control screen, rather than doing what I'm doing at the moment :P
cheers
https://www.sau.com.au/forums/topic/324560-s2-climate-control-question/
just press the auto button, top right i think
thanks chook worked fine.
Plan is to change the standard deck for a single DIN DVD player and hook it up to the xanavi screen. Tax time next month...can't wait :)
