I'm running an hks 2835 pro s which is a modified 3071
car makes 285rwkw on bp ultimate and 325rwkw on powerplus e85
that's 381 and 435 hp respectively
the car has been making this power on stock internals for 2 years now and sees a lot of limiter time
a 3076 will just nudge over my power levels by a few kw.
A z32 afm is an airflow metre from a z32 and will be required to support that kinda airflow
your clutch will hold, but as a single HD won't last forever
Fmic will be fine
as for the stock internals, of course it is a gamble and it could go pop.... But that is life and it's just a gamble you take :banana:
My car wouldnt see a great deal of the limiter as its just going to be for street use.
The car was bog stock when i got it and i have just be doing the breathing mods mainly but now want to up the levels.
So this really is the maximum power youl get before mass amounts of money are required. And 450 at the wheels is a pretty nice amount.
What is the fuel rail??? i have seen a few around but it hasnt been mentioned as something id need, any help there???
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290191
  • Replies 78
Stock fuel rail is more than adequate for these power levels :ninja:
also don't forget that without spending a few grand on suspension and diff, a 300rwkw is next to pointless
if the car is purely for street use I'd be looking at a highflow turbo, intank fuelpump, injectors, afm, return flow cooler, stock or stock looking airbox and nistune if it's available for gtt's. Shoot for 250-270 rwkw which os more than enough for street use
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290231
Hi mate, yeah its going to be purely for street use,what u mentioned is sounding pretty bloody good at the 250-270rwkw.
Would i need an ecu or would they remap the old one when it gets tuned??
And what would be the best order to get this done, im assuming that the turbo would be the last thing on the list??
front mount which already have, fuel pump and injectors, afm, and then the turbo last?? or get a new turbo and put it in but run only run low levels until the others are done??
Appreciate your help mate.
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290250
Turbo has to come last and ecu first as you will need it to handle bigger injectors and afm
Is that buying a new ecu or get it remapped and let them know whats going to be happening to the car??
As for afm, would the bosch z32 afm be suitable for this??
And injectors, something around 500cc???
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290262
Not sure what the e85 or z32afm are??
No offense dude, but if you're asking these sort of questions, 500whp isn't for you...
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290276
Bosch afm is correct
you need to have a standalone ecu OR a remap done for the bigger injectors and then again when the turbo goes on
it's cheaper in the long run to do it all at once
500cc's will suffice, but given the price difference is minimal I'd be looking at 700's
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290277
couldn't agree more! and a much quicker way of doing it, instead of having your car off the road all the time to have work done to it...
i disagree
y would the kid sell his car to go buy a car that has been built by someone else.
ppl dont build 300-400kw cars to cruise around in, theu build them to thrash them.
ive just started my build up and there is no way i would have done it on a car that was already modified i bought a stock car and started from scratch.
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290302
Ok no worries, would it be ok to do it all with minimal driving and get a first and final tune up done when finished??
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290304
i disagree
yeah mate im with ya 100 percent here, thats also why i didnt get a skyline that had been owned over here yet.
first owner, and stock as hell when i got it.
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290309
i disagree
Because you let someone else sink the 20k into it...
If the car has been built properly, there should be no issue with it being driven hard at all and resulting condition.
Starting from scratch just costs you more for the same end result really.
I know a number of people who've picked up well modified examples that are still fine 2-3 years on... absolute bargain and saved them a good 10-15k.
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290322
I have to agree with ash here...
If I was to do it again I would definately buy a built car.
Sure it's nice and romantic to DIY it, but in the long run it will just cost you an ass load of dollars
you can always buy a car that has a known history from a club member
if I was building a 34, personally I'd just max out the stock fuel system, strap on a highflow & ecu and shoot for 230rwkw
Then I'd bomb 5k into handling mods and have an insanely fun car...
That or buy a built one...
I love my 300rwkw car, but if I had my time again I'd let some other sucker pay for it
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290372
Well all im thinking of doing is changing the fuel pump and injectors. the afm, and when the time comes, a 350hp turbo.
That there as you said should hopefully get to 250rwkw and il be stoked for a street car.
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290381
nistune
would i be ok doing my setup and getting nistune installed and obviously tuned when i am finished.
Or would i need to have it installed before and tuned. do what i want to do and when finished have a retune.
Budget is tight so if i could get away with leaving it till the end, that would be good????
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290749
Soon as you changes things like AFM, injectors = retune.
If you are on a tight budget, then simply you shouldn't even be aiming for 300rwkw to be honest.
Settle for 250rwkw give/take with a bolt-on hi-flow turbo and just drive it
https://www.sau.com.au/forums/topic/324609-500hp/page/2/#findComment-5290777
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
