  • Replies 78
start searching and reading. theres shitloads of threads on this.
highflow will make that sort of power, just. and does bolt on
could you point me in the direction of these threads or what exactly to type in the search bar???
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5292671
no its not a direct bolt on
What are you on about, you can get an internal gate GT3076 to suit a stock T3 manifold flange with the stock nissan 6 bolt dump, they brought them out a few years ago :)
Here: http://www.horsepowerinabox.com/HPIAB2/category12_2.htm
Fair enough you have to change the lines and might need to modify the intake piping, but I still call that a bolt on.
Edited by PM-R33
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5292765
those "bolt on" gt30s are not the type nismoid was reffering to as they realistically will never make 300rwkw. only a proper gt30 with a garrett housing will. and besides why the hell would you want to go to all the effort of buying a good turbo, changing lines etc then put a shithouse rear housing on it just to save the last few dollars on a spacer plate and dump pipe.
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5292904
Well I never said I was going to buy one, but for the OP's situation he doesn't want to spend to much and he wanted something bolt on and asked if you could get a GT3076 as a bolt on, which technically you can. Personally for his situation I would put a 6boost on it with a proper externally gated GT3076, however that is easily going to push things towards the $10,000 in parts range.
Edited by PM-R33
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5293127
Technically you can - but for what he wants, it's a proper housing all the way IMO.
Either way i still think the best course of action is for the OP to simply buy a GCG Hi-flow.
Bolt onto stock bits for around $1700, best of the best as far as hi-flows go, will make ~250-260rwkw and be done with it.
Motor will last forever given good servicing/tune and not sitting on limiters etc.
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5293145
I have been in contact with the tuner and he said that the GT30 high flow would be a good choice, look factory on the car and get around the 260rwkw mark.
Is this turbo the "GT30BB" on horsepowerinabox??
As this should bolt up to the stock manifold and be a good option.
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5294157
That is a high flow using GT3076 BB CHRA, Basically machine your factory housings to suit it. it will produce about 260rwkws after a decent tune. Once high flowed every thing bolts back, no modifications required. We can carry out this service at a very decent cost.
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5294368
How much to high flow my current stock turbo, rb25detneo. And what does this involve??
Would like to be able to rebolt back on and not have to modify anything.
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5294384
It is NOT a good choice.
A GT3076 CHRA is a 300-320rwkw style of turbo.
Putting it into stock machined housings is silly as we've already said in this thread - use GENUINE housings.
Just get a GCG item if you want the best bolt-on hi-flow.
Otherwise if you don't then next step is SAU Traders, they offer varying products that are cheaper.
Stay away from 'butchered' turbos like a GT30 into a factory housing set.
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5294518
Ok no worries, thats off the list.
I think the GCG is a go.
Appreciate your help mate.
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5294580
The GT3071 450HP or GT3076 52T 480HP is the better CHRA profile for OP6 factory housings and a common high flow profile. It will produces better response as well as smoother power delivery compare to 450HP traditional TA34 cropped turbine wheel 71mm comp wheels.
Do a compare in the dynosheet section and you will find out. The person whom mentioned a "butchered turbo" doesn't intact know what it is or much about highflowing. While my advise is based on solid evidence.
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5294605
At first you try and sell him a GT3076 in a OP6, and then now you are saying that it wasn't the best course of action and there are better alternatives? :blink:
A GT3076 in a OP6 housing, is a butchered turbo. The 500-550 compressor is not suited to such a housing at all.
It is best suited on a RB25 to a .82 Genuine rear housing and you know it.
Then you have the audacity to try claim i know nothing? :P
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5294624
A GT30 in a OP6 housing, is a butchered turbo. The 500-550 compressor is not suited to such a housing at all.
GT3071 56T or GT3076 52T is the best possibly solution. One's rated to 450HP and the other's rated to 480HP. They are not rated to 500~550HP and you are only thinking about the 76mm 56T or larger trims which the factory comp housing run out of materials
The dynamic of the GT30 turbine wheel is lot better then the older style of TA34 crop, in terms of:
1. Taller inducer area: resulting better turbo response and greater exhaust flow.
2. smaller inducer dia, less turbine fins: resulting less overall weight, contributing to response.
3. Larger gaps between fins: resulting better exhaust flow less back pressure.
and I'm very sure that you are fully aware of that. the Higher flow rated turbine wheel the better it is for high powered high flow applications as you are dealing with a very restrictive turbine housing.
on Road the GT30 turbine wheel comes in earlier and provides lot smoother power delivery.
I'm not interested if we get the deal. But the OP needs to have the correct correspondence and best recommendation to his solution.
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5294640
For the money and effort involved to "Hi flow" a GT3076R into a VG30 BB OP6 housing I don't think its good bang for buck . For starters if you use the port shrouded T04E compressor housing , stupid not to with a smallish turbine housing , you'd probably still have to space it out and all of the air/water/oil plumbing has to be changed . One off bits and pieces that cost silly money compared to simply refitting the std plumbing like you can with the GCG type Hi flow .
Nismoids right , a 3076 with all is dogs barking can easily break 500 Hps worth of airflow but the reason why people never get all 43 beans out of them is they won't use the largest 1.06 A/R GT30 turbine housing .
As for the 52 trim versions of the 76.2 mm GT37 compressor , they're not that far behind the 56 trim version and the 7/7 bladed compressor wheel versions I wouldn't piss on .
I'll be blunt , most people new to them don't know what 450-500 Hp is like at the engine let alone the wheels and you can reach the traction limit of any RWD Skyline real easily without anything like that kind of power .
Also an RB25 is never going to be what you'd call crisp and responsive cranking 450-500 and I don't think it would "feel" like a fast exciting road car to drive . Dunlop destroyer yes , sporty - no .
I know what the SK GO33GO went like and it was silly fast and still couldn't use everything it had through its two driven rear wheels . It was quick and responsive and felt like a real fun car to drive .
From memory it cranked out about 266 Kw at the treads and amongst other things used a GCG Hi Flow with an OP6 turbine housing on it . A real OP6 not the aftermarket one .
Now big turbos and OE style turbine housings . This is always setting the system up for a fall because rarely is the waste gates ability to bypass enough to cope with the airflow into , meaning greater exhaust flow out of the engine .
At the very least the bastard hybrid should have a port shrouded compressor housing because the turbine housing is pretty small compared to the turbines native ones and will try to spin it up early with all the restricted hot side and boost creep issues . But people still do it and still run into the same hurdles - and the turbo still doesn't get the user up to its advertised power level so really you have to ask yourself - why go there ?
I beg you to reconsider the difference between 266 and maybe 280 bastard Kw . For the expense the lag the lack of traction when it all comes in with a bang and chronic boost control issues .
The GCG OP6 really is the better option and the smart economic one . Jesus christ it even LOOKS standard and fits up with all the cheaply available factory hardware .
IMO the 15 extra Kw of wheel spin you won't miss , nor the defects or the greatly increased cost of using the Garrett turbo .
Invariably one day you gonna want to sell out of this car and when you compare the build cost to the sale price you cry a lot less when the numbers are closer together .
Build usable power , anything else on the street is lunacy .
Your call , cheers A .
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5294892
280odd rwkw is not laggy when setup correctly tho.
I make 20 psi by 3400 revs in 4th on a dyno, and on the street it is literally within a few revs of that in all driving conditions
it's progressive enough no to be a lightswitch but get up and goes well quick enough to still be considered a fairly responsive car. It's a pleasure to drive both on the street and the track. (the power level, not the suspension)
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5295072
First of all this is just a friendly discussion about highflow profiles, I'm not trying to insult any one else who is in the business and hope you are all reading it with the same manner. The all overall solution might help to produce a even better high flowed unit or a better combination for future customers.
Looks like every one's got their own opinion about high flows.
I believe the current GCG high flows runs of GT3071's 56T 71mm spec comp wheel with a Cropped TA34 turbine. and I'm taking about the Same comp with GT30 turbine.
The main agenda is on the turbine profile which needs to work with a restricted OEM housing, the better flow the more power.
The GT30 turbine wheel compare to a TA34 Cropped turbine wheel. The GT30 wheel produced 20kws more at 4000RPMs while still making the same top end, and that is very noticeable difference in on road.
The water lines and etc are just all minion details which can be modified before assembly.
Any way, as you stated that GT30 profiles pickups better power and response which results in un-useable power band, I think that’s good enough reason for to sticking with that.
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5295682
I'm not the greatest fan of the humble GT30 UHP turbine , it's not that it isn't a reasonable design but the 84 trim size IMO is too big . Some of the later larger GT turbines (GT37 and GT40) are being used in 78 trim size and it should have filtered down to the GT30 and GT35 UHP turbines - IMO .
The GT28 NS111 turbine tops out at 76 trim and the sadly competition only 60mm version of that design (TR30R family) is available for those units in 73 or 76 trim .
The largest of the TB31/TA34 turbines is 76 trim , the largest of three sizes .
BTW the compressor in the said Hi Flow isn't a 71.1mm GT35 series wheel , I have seen one bare and deliberately didn't turn it over to look at its part number - didn't want/need to know .
A .
https://www.sau.com.au/forums/topic/324609-500hp/page/4/#findComment-5296372
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
