Near new bought on the 17/05/2010 at Orange IT in Sydney. Box still available. But receipt will try to find for it.
Include everything comes with the box. 2 years warranty.Can support cod4 and bad company 2 no problem at all.
Price: 1500 ono
SMS or call: 0430857511 Jon
Spec:
Intel Core 2 Quad Q9000 2.0GHz
17" Ultrabright™ screen
4GB DDR3 RAM
1TB HDD
Nvida Geforce GTX260M 1GRAM
Wireless N
Bluetooth
ESATA
HDMI
IEEE1394
Windows 7 Home Premium
9cell battary
Reason for selling: My gf bought me a new apple laptop so no use for this anymore.
Pickup at Ryde area or maybe around sydney area.
cheers
Edited by akajonz
https://www.sau.com.au/forums/topic/324614-fs-gateway-gaming-laptop/
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
    • Brakes definitely won't make him faster. They only slow you down. 😛
