Hey SAU,
My 32 seems to missfire at high revs say about 3500 grand onwards on and off. . . I've looked at other topics but I've already changed allot of parts to try and fix the problem . .
I've installed new spark plugs (plat/iridium) and new coil packs ( super spark) and changed my air filter I've checked for boost leaks but cant find any. . and there isn't any water in the fuel tank I've even tried changing the pressure of the fuel with a sard FPR but yeah still nothing works . . i also thought to drop the boost but that made no difference either so I am dumb founded to what it could be . .
any help would be appreciated :banana:
cheers..
  JKR-32 said:
could be ignition module, or coilpack loom. or afm maybe...
those are probably all worth checking. probably one of the first 2 though
afm = air flow metre?
yeah ive checked the coil pack loom already but havent checked the ignition module yet i cant seem to find any anywhere :) . . ive even disconnected the sensor on the dump pipe cause apparently that sometimes causes it. but that made no difference. . the revs are really bad too it fluxuates around 200 to 600 revs . . i just had a play with it again then and i'm thinking it might be a vacuum leak somewhere i just cant find it :banana: cause that'll explain the fluxauting id;e revs and when i try and boost it past 7 pound thats when it starts missfiring it has nothing to do with how many revs i give it :P
do you think i should just get rid of the stock intercooler and just redo it and put a front mount and change all my vacuum hoses?
  Bl4cK32 said:
check spark and fuel. Injectors had a clean anytime?
i had the injectors cleaned also when this started first occuring :banana: and they passed flow testing also
  R31Nismoid said:
List of full mods. Sounds like something is up
Why do you have a sard FPR? What ECU setup?
super spark coil packs
plat/iridium sparkies
3" cat back 5zigan exhaust
hks pod filter
had a boost T but just took it out to see if it made a diff but it didn't . .
sard FPR ( was gonna increase the flow when i put other mods in it so its just running standard flow )
f/r strut braces . .
boost gauge
thats about it its not really worked or anything :banana:
  R31Nismoid said:
coil pack loom or the ignitor will be stuffed then by the sound of that.
And don't use iridi plugs - you've probably already fouled them again which isnt helping.
Use coppers.
oh true copper ones huh??
well i'll def put some new ones in then :P and try and source an igniter :ninja:
Well dont change them if they aren't stuffed - but my guess would probably be until you get the issues sorted out... then you'll keep fouling plugs and iridi's foul super easy.
So even if you fixed the issue, you'll have plugs that are stuffed and not helping/showing the same symptoms as before
did u say u changed the fuel filter?
if i was you, id drop into a local garage that has a scan tool, and get them to check for any sensor faults.(providing they have the correct adapters ect, on my r32 the adapter is just above the fuses in the cabin of the drivers side.mines a 14 pin connecter, but they also come in 16pin)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
