Past few weeks ive noticed car making popping sounds (machine gun like/powerdrill sound when u cant drill any further) when on about 11-13psi throughout the rev range. So i turned boost controller right down and it is still doing it, but in higher rev range. Also with turned down it just spools slower but is still 10-12psi????
anyone have any ideas.....
https://www.sau.com.au/forums/topic/324637-weird-sounds-when-on-boost/
missfire?
check your plugs and coils.
gap your plugs down cos it seems your boost is blowing out your spark.
or it could be detonation you're experiencing, what fuel are you using?
p.s. might help to list the mods your car has mate lol. then weve got some sorta idea what your engine is dealing with...
3" cat back, pod filter, hybrid intercooler, el cheapo manual boost controller go fast bits.
i only run bp ultimate fuel.
gts-t r33 series 1
it is worse when its colder temperature outside .... e.g. night and early morning
I beleive you have found richen and retard airflow point in your stock (?) ecu, once the computer senses a certain airflow it will richen the mixture and retard timing. The reason this could be happening now when it wasnt before could be due to the colder weather, colder denser air = more total air into the engine at the same boost. Try turning the boost down to stock and see what happens!
washed engine bay like 6months ago, i did clean MAF sensor a 2weeks ago... i tried winding boost down, i will try other way in case i opened it up, but as per instructions it is down as it seems to stay under 15...... holds on 10psi then higher revs when spiking over 10psi it hits the noises.
R&R for sure
^^^ What he said
how do i overcome this
Wind back the boost..... 10psi is sometimes enough for the ecu to R&R....
Your could also try re-setting the ecu and see how that goes.... If it hasn't been done for a while, it is well worth doing.....
if it helps, i got a sII with similar mods.. mine was making the same noise when i first bought it.. turned the boost down to stock (had to do a bit of trial an error with the manual boost controller and the boost gauge) running 7-8psi no missfire/popping noise when foot is flat on the gas.. I tried turning the boost back up a few weeks ago up to 11-12psi, which made it missfire slightly again.
stock turbo / ecu doesn't like anything above 12psi
  • 4 weeks later...
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
