Past few weeks ive noticed car making popping sounds (machine gun like/powerdrill sound when u cant drill any further) when on about 11-13psi throughout the rev range. So i turned boost controller right down and it is still doing it, but in higher rev range. Also with turned down it just spools slower but is still 10-12psi????
anyone have any ideas.....
https://www.sau.com.au/forums/topic/324637-weird-sounds-when-on-boost/
missfire?
check your plugs and coils.
gap your plugs down cos it seems your boost is blowing out your spark.
or it could be detonation you're experiencing, what fuel are you using?
p.s. might help to list the mods your car has mate lol. then weve got some sorta idea what your engine is dealing with...
3" cat back, pod filter, hybrid intercooler, el cheapo manual boost controller go fast bits.
i only run bp ultimate fuel.
gts-t r33 series 1
it is worse when its colder temperature outside .... e.g. night and early morning
I beleive you have found richen and retard airflow point in your stock (?) ecu, once the computer senses a certain airflow it will richen the mixture and retard timing. The reason this could be happening now when it wasnt before could be due to the colder weather, colder denser air = more total air into the engine at the same boost. Try turning the boost down to stock and see what happens!
washed engine bay like 6months ago, i did clean MAF sensor a 2weeks ago... i tried winding boost down, i will try other way in case i opened it up, but as per instructions it is down as it seems to stay under 15...... holds on 10psi then higher revs when spiking over 10psi it hits the noises.
R&R for sure
^^^ What he said
how do i overcome this
Wind back the boost..... 10psi is sometimes enough for the ecu to R&R....
Your could also try re-setting the ecu and see how that goes.... If it hasn't been done for a while, it is well worth doing.....
if it helps, i got a sII with similar mods.. mine was making the same noise when i first bought it.. turned the boost down to stock (had to do a bit of trial an error with the manual boost controller and the boost gauge) running 7-8psi no missfire/popping noise when foot is flat on the gas.. I tried turning the boost back up a few weeks ago up to 11-12psi, which made it missfire slightly again.
stock turbo / ecu doesn't like anything above 12psi
  • 4 weeks later...
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
